EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   heeelp code (https://ecomodder.com/forum/showthread.php/heeelp-code-12115.html)
passat19tdi 02-01-2010 02:29 PM
heeelp code
1 Attachment(s)
http://www.okazii.ro/catalog/3796363...RIN-POSTA.html
which is the most appropriate source code for the Arduino(atmega 168)
I B4 Passat TDI
I am from Romania and I need units of measure kilometers and liters
Thank you in advance
yetimus 02-01-2010 10:12 PM
I used this code: http://opengauge.googlecode.com/svn/...no/mpguino.pde. You have to modify it slightly to work on the Passat's fuel consumption signal. Find this line in the code:
attachInterrupt(0, processInjOpen, FALLING);
attachInterrupt(1, processInjClosed, RISING);
and change it to:
attachInterrupt(0, processInjOpen, RISING);
attachInterrupt(1, processInjClosed, FALLING);
More info on it here and here.
Good luck!
passat19tdi 02-02-2010 10:18 AM
thanks for the reply
not find here the role of buttons
What role have?
function?
explain me
thanks
passat19tdi 02-27-2010 01:37 PM
1 Attachment(s)
I finish mpguino
I installed on car
calibration fail
I used code 075
yetimus you what values to use VSS pulse / miles?
the calculations and the board is clear indication that the value of pulse / km would be about 2138 pulse / km, but the information is incorrect
sometimes show the real speed sometimes appropriated to 100km / h over
I think the information is correct injection fuel value is correct
passat19tdi 03-28-2010 06:44 AM
I did upgrade to mpguino with atmega 328
I used code 080 to indicate l/100km with Arduino 13
mpguino not indicate anything, the speed of 000.00, 00.00 instant tank .....
I entered as code 079 and 00.00
I entered code 075 as one who works well with atmega 168 and runs on 328 as well but now the tank instantly indicate l/100km
I entered the fog do not know what to do
Copyright ©2000 - 2020, vBulletin Solutions Inc.
