Hello
Hi, I'm James. I'm from Washington state, and my daily driver is a '99 Jeep Wrangler that I've swapped a 2.2L Kubota diesel into.
Very nice!!!!!!!
We love swaps!!! Have you raised your psi in the tires? |
Welcome! Another western Washingtonian! I live in Puyallup and work in Tukwila.
Do you have details on the engine swap somewhere? I've thought about similar swaps a few times, but I need to finish some other projects first. |
A friend machined adapters for the stock flywheel and transmission for me, so it's original Jeep from the flywheel back, and the starter is also the original. There are quite a few builds with these engines in the diesel engine conversions section of Diesel Bombers if you want to see builds and results without all of the muck. http://i24.photobucket.com/albums/c1...pse78eb47e.jpg http://i24.photobucket.com/albums/c1...226_112651.jpg http://i24.photobucket.com/albums/c1...012_231707.jpg http://i24.photobucket.com/albums/c1...ps86db4171.jpg http://i24.photobucket.com/albums/c1...010_193348.jpg |
Welcome to the site. Interesting swap you have there. How do you like it?
If you feel like posting a summary / highlights / lowlights of the swap here, you can bet people will be interested.
Welcome to the site. |
Very cool I really like this Jeep! Welcome to the site.
Thanks, I love it! There have been teething problems, like any new combination, but it's getting better and better.
The engine came from a Carrier refer unit, but they're used in some Bobcats, tractors, and other applications. Rating is around 50HP/100TQ naturally aspirated. I added the turbo and intercooler. The turbo and some fueling changes dramatically improved the performance. A friend that put one in his Ranger with a very similar setup to mine just had it dyno'd last week, and it pulled 98hp @ 2200RPM and 278 ft lbs @ 1800RPM at the rear wheels. The picture is a year old. Since then I've tried several different turbos, so the downpipe in the picture isn't currently in use. Right now it's using a 2.25" pipe all the way, but I'm in the process of building another 3" system with better routing and design. I'll try to write something up with more detail when I have more time! |
I looked into the specs on that Kubota and didn't get real excited over the ~50hp rating... 98hp sounds a lot more reasonable. I saw he was getting 40mpg or so too. Not too shabby for a 4WD Ranger with oversized tires. |
Great swap! Any mileage numbers?
Forums can be not so nice places. If you go against what everyone is doing, you get flamed. But, going against the forum isn't always a bad thing. You made the engine work, right?? Good for you. I'd love to do a 4BT swap into a quad cab Dodge Ram with a manual transmission. I don't have the time to though. |
I got my new manifold, turbo adapter, and turbine housing back from the ceramic coating place last night, and I should have it back on the road tonight. I was using the original NA manifold, and I had some problems keeping a good seal to the head and turbo, and there was about a 5mpg difference when it was leaking. The turbo manifold has much thicker flanges, and 4 bolts on the turbo flange instead of 2. The runners also stay the same size as the exhaust ports all the way to the turbo, have fewer obstructions, and are directed at the outlet. The NA manifold had obstructions where there were more reliefs for bolt access, very little flow directing into the outlet, and grew to about 1.5x the diameter by the exit. I'm hoping the turbo manifold helps keep it sealed and maybe the better runner design and ceramic coating will add some low RPM performance. |
SWEET swap! Super clean install, looks factory.
25 mpg in a Wrangler? I think I gotta call Mom. She drives a Wrangler, and getting out of the mid-teens would make her day. +1 on the call for the build story. There's a thread I'd subscribe to. |
It's back on the road with the new turbo manifold and old turbine housing back from the ceramic coating place!
Before - Kind of hard to see, but I don't have a better one http://i24.photobucket.com/albums/c1...ps8539bb5f.jpg After http://i24.photobucket.com/albums/c1...psusky53i5.jpg |
