Hello From Dk (showing my Renault Clio)
1 Attachment(s)
Hello From Denmark, So i bought this 2018 Renault Clio 1.5 dci brand new from the dealer, i have owned the car for almost 9 months now and put 100.000 km on it.(still original wiper blades and brake pads) the engine is an 8 valve 4 cylinder turbocharged diesel. With a low pressure egr valve. It is the smallest car to come standard with an active grill shutter. I bought the original Renault Zoe 16 inch "Aerotronic" Rims which returns the same consumption as the smaller 15 inch aluminium rims.
I plan on getting it lowered 40 mm. and cutting of the rear muffler. As I drive a lot on the Autobahn in Germany at high speeds My average consuption has been aroun 4.7 liters per 100 km but my record is 3.8 liters per 100 km on 1 tank 1478 km (55 Liter tank) https://ecomodder.com/forum/attachme...3&d=1542489721 |
Welcome to ecomodder , Rasmus :)
The wheel shape and tyres seem to compensate for the (usually) higher weight (and higher fuel consumption) of the bigger rims. Quote:
Reducing back-pressure may make the engine run worse, not better. Quote:
If you want to drive fast, you need to look into aerodynamic modifications. |
Thanks you Very Much and yeah i drive 11000 km a Month. :) the tires are the Stock Michelin Energys saver. Removing the muffler in a diesel reduces exhaust temperatures and gives less backpressure. Aero mods is a Good Idea but i want to keep the car original on the outside
Welcome to the site.
