EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   Hello Ecomodders (https://ecomodder.com/forum/showthread.php/hello-ecomodders-36455.html)
Raj174 05-13-2018 01:54 PM
Hello Ecomodders
Recently bought a Hyundai Elantra Eco and was looking for info on how to improve MPG through better driving techniques. It looks like I found the place.
MetroMPG 05-13-2018 05:36 PM
Welcome Raj174! You found us.
How new is the car to you? Have you got baseline results for it yet?
Definitely the first step is to start tracking your MPG so you can monitor your progress.
Raj174 05-13-2018 07:02 PM
The car is brand new. Bought it on April 25th. I'm on my second tank of gas. I got 39.12 mpg (actual) on the first tank, 80% city driving. Not sure if that is the baseline you mentioned.
I try to time the stop lights, but they seem to conspire against me. I coast when I can, but try not to be a nuisance to other drivers. I'm sure I have a lot to learn about ecomodding.
MetroMPG 05-13-2018 07:10 PM
How close was actual to the car's MPG gauge? Is the factory gauge useful? How many (instant/trip)?
Baseline... I just meant what you were getting before you got serious, but it sounds like you're already serious. Keep a fuel log here or somewhere so you can watch your progress.
39 is great, especially for a brand new car. It'll improve as the car breaks in, all else being equal.
Does it have a "manual" shift mode? Sometimes you can manually upshift before the programming will.
California98Civic 05-13-2018 07:59 PM
I love these cars. At 60 mph I bet your RPMs are down at 1900 or so, no? Hyundai has become a great global automaker.
Raj174 05-13-2018 08:48 PM
The factory guage was very close, less than 1 mpg above actual.
Yes, I am serious about mpg efficiency, I bought a new Toyota Prius in 2008 and drove it till I traded it in on the Elantra. It got great mpg, 52 average here in Tallahassee. However, it had a few mechanical problems that I had repaired so I decided not to push my luck by keeping it.
I know how to drive the prius to get the best mpg, but the Elantra is a completely different type drive train. The prius thrives in stop and go traffic, the Elantra does not. The Elantra likes a steady even speed, from 15 to 60 mph. As long it is a steady speed it will be getting over 50 mpg. I'm sure it is because the 1.4 turbo GDI is so efficient.
It does have a dual clutch 7 speed transmission with manual shift, but I really don't know the proper time to shift to improve mpg.
By the way, thanks for the pointers.
Raj174 05-13-2018 08:57 PM
Yes, very close to 1900 from what I can recall. I agree, they have become a quality company and it shows in their vehicles. I think they are nearing Toyota and Honda quality. That is why I thought the Elantra Eco would be a good choice.
mpg_numbers_guy 05-13-2018 10:07 PM
Welcome to Ecomodder! Be sure to check out 100+ Hypermiling Tips and 65+ Efficiency Mods for some inspiration and ideas! :)
Effic1ent1 06-28-2018 06:14 PM
Pump up the tires psi. :)
California98Civic 06-28-2018 10:10 PM
According to Jalopnik, Hyundai claims a drag coefficient of 0.27 on your car. Nice low number. https://jalopnik.com/the-2017-hyunda...pgs-1743512995
Raj174 06-28-2018 10:33 PM
They are currently set to 36 psi. What pressure do you recommend? Sounds like it might stiffen the ride and wear the tire tread down unevenly.
redpoint5 06-28-2018 10:54 PM
It will cause a stiffer ride and probably a little more road noise, but it shouldn't affect tire wear. I run somewhere around 43 PSI on my Acura and appreciate what it has done for handling, but dislike the extra noise. Just experiment and see what is a good compromise for you. The higher the pressure, the better the MPG.
Effic1ent1 06-28-2018 11:03 PM
You can go up to the max psi on the sidewall without worry, but it will stiffen the ride. That's up to you if you want a little better fuel efficiency or a comfy ride. Wayne Gerdes puts like 60+psi in his tires and they last twice as long as the tire mileage warranty, but that's just one example. Many people on this site go to crazy lengths to eek out an extra mpg or two and are willing to have a hay wagon ride to get it. It sounds like you just may want to hone in your hypermiling technique.
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Beating the EPA - The Why
elhigh 07-03-2018 02:43 PM
I run my tires at 45-50 psi and haven't noted any accelerated or aberrant tire wear. Road noise increases a little bit, and you feel the bumps more.
NOTE: I think it may also contribute to going through headlight bulbs faster than other cars, so if you're looking for an excuse to upgrade to LED headlight bulbs, now is the time.
California98Civic 07-03-2018 11:23 PM
i pump tires to 55 or 60 psi always the last 90,000 miles... have noticed no odd wear. more noise. Stiffer ride. Much better FE.
rangerrick 07-07-2018 06:45 PM
Hello every I have a 99 ford ranger. It is a 4 cylinder 5 speed manual transmission. It is a 2 wheel drive short bed. I average abput 20 mipg and i would like to get to 30mpg.
California98Civic 07-07-2018 07:12 PM
pretty good platform to start with. what mods or hyoermiling techniques are you considering?
rangerrick 07-08-2018 04:49 PM
Thanks. I plan on a few aero mods. I want to make an aero bed shell. Of also like to add wheel covers and rear wheel skirts and a front air dam. I plan on starting with a vacuum gauge to help my driving habits. I will need to eventually get a scan gauge to finentune my driving habits. My commute is 12 miles and 90% of its highway
California98Civic 07-09-2018 09:47 AM
Great. Start a new thread for your vehicle so people know you are here and what you are working with.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
