Hello from germany.
1 Attachment(s)
Hello from germany, the country of unlimited highway-speeds and expensive fuel.
I've been looking around in this forum before to save some fuel. This has resulted in me archiving a record of 5,93L/100 km (40 mpg) in a Toyota MR-S (5-speed manual 1.8L 140PS DOHC VVL mid engine RWD) under not exactly ideal conditions. Your EPA rates it at 22 city/27 highway/24 mixed, wich is rather easy to beat. I hope to improve on my current record by learning a few more techniques as well as slightly modifying my car. Sadly I can't do as much as some of you guys do or the Police and TÜV get angry... |
I miss that beautiful country! When I came home I wondered why every Prius owner drove like Audis in Germany.
Welcome to the site! |
A modification I've got an eye on is to use parts form a different C-series transaxle to get either a taller 5th gear or do a 6-speed conversion with a realy tall 6th gear from a diesel. I expect some not insignificant gains as the 5th gear is rather short in the Spyder, causing it to rev almost exactly 2900 rpm at 100 km/h. And it's not like the TÜV checks the casting number of transmissions, so that should be fine. But it would be a lot of work as I'll need to find a donor gearbox and convert it with parts of mine and just getting the gearbox out is a rather complicated process... |
So perfect car! As I see on Wiki, it is below 1000kg.
Welcome to the club! |
When I said effective, I was also considering how under the radar it would stay.
I think the results should be noticeable.
When driving on the Autobahn at ~90 km/h in the right lane, the engine is reving ~2500 rpm at a realy low load. The BSFC is likely rather bad at 2500 rpm and low load. Shifting it from 2500 rpm and low load to 1800-2000 rpm and higher load should do something. However that mod is likely going to wait for a while. Before that I'll experiment a little with the aerodynamics and likely swap tires. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
