Old 03-07-2010, 03:43 PM   #1 (permalink)
Racer XD - '06 Hyundi Elantra GT
90 day: 33.26 mpg (US)
Racer XD 2013 - '06 Hyundi Elantra GT
90 day: 31.48 mpg (US)
Racer XD 2014 - '06 Hyundi Elantra GT
Racer XD 2012 - '06 Hyundi Elantra GT
Racer XD 2011 - '06 Hyundi Elantra GT
Light weight pulley's
I was looking at getting some light weight pulleys for my car. I wanted the increased power from them. But then though do the light weight pulley giver better FE as well as more power?
Has anyone on here ever tried light weight pulleys on their car?
IE http://www.arkperformance.com/Produc...de=BU0701-0105
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 03-07-2010, 04:16 PM   #2 (permalink)
...beats walking...
...couple them with "electric clutch" (like A/C units) and you've got a winner!
Old 03-07-2010, 04:26 PM   #3 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
These would be appropriate on a Bugatti Veyron or a McLaren M1, or you could just use your money for kindling.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Frank Lee (03-07-2010)
Old 03-07-2010, 05:08 PM   #4 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
You'd be better off spending $300 elsewhere to be honest.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 03-07-2010, 05:56 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wildfire8 -
I've been tempted to do it, but I wouldn't be doing the installation. That means it would cost me maybe ~$250 in parts + labor to install. On the advice of others on this site I didn't go for it because it's not worth the money.
I am curious. In the url it says that it requires this belt :
- Requires replacement belt - 31inch size
Is this the same size as your current OEM belt?
Also, have you asked about this on a Hyundai forum? I am thinking they would be able to tell you if there are any benefits and/or side effects.
CarloSW2
American Solar Energy Society
Old 03-07-2010, 06:22 PM   #6 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Going w/ lightweight pulleys could increase FE by maybe a half a percent or so w/ a typical driver in stop and go city, but technically if someone is driving efficiently they shouldn't be stopping and going that much, so it's kind of a moot mod for most efficient drivers. If someone is racing otoh, dropping ~15-20lbs off of the powertrain's rotating mass is the equivalent to adding a few to several HP in first gear depending on the max engine speed/gearing, so it's cost effective in that sense.
Old 03-07-2010, 06:25 PM   #7 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
They would never pay for themselves in terms of fuel mileage.
Old 03-07-2010, 06:29 PM   #8 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Once the mass is spinning it takes very little energy to keep it spinning regardless of weight. The lighter pulley will let the engine spin up faster and down faster than heavy ones. The total rotating mass in the engine is quite large compared to the weight saved with these pulleys. My guess is the only time you would notice them is when you opened the hood.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 03-07-2010, 06:30 PM   #9 (permalink)
[QUOTE=wildfire8;164815]I was looking at getting some light weight pulleys for my car. I wanted the increased power from them. But then though do the light weight pulley giver better FE as well as more power?
IE
FE: Unlikely change as the weight change will be very small but the energy used to accelerate and decelerate the weight saved will not be needed so there will probably be some gain however small.
POWER: See above. Sorry but the power saved will again be small.
If the original pulleys are smooth it may even give less FE and power as the aero drag is increased.
I used them many years ago but to fix some weird harmonic in an engine in a boat which was destroying alternators at a great rate.
The fix by the way was to replace the fancy alloy spoked pulley with plain pressed steel unit with a different harmonic frequency but the same diameter.
It worked.
Pete.
Old 03-07-2010, 06:50 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Peter7307 -
It worked.
Pete.
Thanks for posting this. This is what I mean by a side-effect. Do you remember if the "fancy alloy spoked pulley" was OEM or ???
I think a light weight pulley may introduce the same problems because it's not OEM. That is why I wanted to know if someone on a Hyundai forum had done this.
CarloSW2
engine, light, mpg, pulley, weight
light weight rims and narrow tires diesel_john EcoModding Central 21 03-11-2016 09:17 PM
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
4th brake light and Rear fog light. Sean T. Off-Topic Tech 10 11-27-2008 12:29 AM
Lowered the Ranger with light weight rims.. FX2.3 Aerodynamics 38 09-23-2008 02:48 PM
