Hello from Ireland
Hi, I've been browsing the forum for a little while. Both my cars are reasonably fuel efficient. My first car is an Alfa 156 2.4 Turbo diesel. The govt mpg figure is 42 (UK), but I get around 48. I bought a Smart Roadster coupe at the start of summer, the govt mpg on that is 55 (UK), but I've struggled to average that since I've got the car. However, on my last tankful where I was trying very hard I managed 61 mpg (51 US).
Interested in improving the Smart Roadster's aero, as while the cdA would overall be quite good as its low slung, the body shape is fairly pants! Having said that, the Coupe model I have has a Kammtail which improves the topspeed against the ordinary Roadster by 3mph! Also I'll be looking at the current crop of euro cars with eco aero detailing and comparing them against their normal trimmed models (VW bluemotion, Ford econetic, vauxhall ecoflex). See you later, Damien |
Example of a Smart Roadster:
http://obchod.spstyling.sk/images/ca...oadster_xx.jpg Smart Roadster Coupe (identical to my car) http://www.carandclassic.com/uploads/new/47590.jpg Smart Roadster v Roadster Coupe Kammtail: http://www.pozitifpc.com/editorblog/...ster_coupe.jpg Smart roadster coupe rear http://motortorque.askaprice.com/ima...uilt-20716.jpg |
I've also got a Smart Roadster, although mine's a notchback, rather than the Coupe. I've fitted Michelin Energy tyres (40psi) and removed the antenna so far. I've got a big list of stuff to do, just not got round to it yet. I've been planning a coupe conversion (without the big hinges) and a few small changes, like taping up the gulleys behind the doors and removing the mirrors.
I did a run from manchester to edinburgh and back in a friends coupe the other month and got 67average which included enjoying myself going over the 'beeftub' road. he runs standard size tyres @38psi but thats it. I was stunned how comfy and quiet it was, I was expecting it to be a lil buzz box.
Good luck Damo keep us informed ! |
I've never done that well on my economy but then, I do enjoy my driving! What amazes me is that I can do a track day and get 36mpg. I suppose that's why I've not been too bothered about doing mods. You must have had low expectations of comfort and noise if you thought the Roadster was good. It's the noisiest car I've ever had and it's hardly the height of comfort, although I did manage 3800 miles around Europe last month and my 170 mile trip to the office and back is fine.
Welcome Damien.
Thats a very nice machine you got there. Is your coupe a manual or auto/tiptronic? ollie |
There's never been a manual. It'll be a tiptronic, which is a manual three speed 'box with a two speed overdrive and all electrically operated. The driver just uses the gearstick in the centre console to select drive/neutral/reverse and tap forwards to change up, pull back to change down. Whilst there is a clutch, it's operated by the ECU and there's no pedal. There's an optional extra to have gear change paddles on the back of the steering wheel too.
the only big issue I had was that the tip stick was a push away to go 'up' and pull back to drop a cog, which just seemed wrong and un natural, there was a couple of times where I buzzed the engine when i pushed it the wrong way!:D |
When you look at them closely, the Roadster's aerodynamic aren’t great. They do have some things going their way.
Small frontal area • Almost full undertray (apart from under the engine at the back) • The Coupe has quite a nice Kammback. • Front panel gaps are good. However, there's loads of bad stuff too (in order of importance IMO): • Huge bulbous front wheel arches (The single worst aero feature) • Air intakes along the side of the body (2nd worst) • Round recessed headlights • The wipers are in an area of high pressure and almost unshielded • The side mirrors are quite big for the size of the car. • As standard the wheelarch gaps are quite big (7cm) for a small sporty car. • The Tridion stands proud of the rest of the bodywork at the sides and top (esp noticeable on the Coupe). • Large external hinges on the coupe. • Wind deflectors for softtop. These are pretty much required to reduce the soft top wind noise and buffeting. • The panel gaps round the doors are terrible (about 8 mm). The main problem with the bulbous wheel arches, side air intakes and wheel arch gaps together is the unattached airflow along the side of the car. I have made some mods: • I put brown P profile weather striping along the side and bottom of the driver's door. Used "Back to Black" to 'paint' the strip black. • Moved the front number plate up (to partially cover the front grille/ air intake) • I made polystyrene blocks to fit into the sides of the front grille. Covered them with black insulating tape. • I made a clear plastic deflector to deflect air past the driver's side-air intake. • Changed the normal aerial to a shorter stubby. • Pushed the side mirrors back a little • Disconnected the Electric power steering • Upped the tyre pressure to 31/30. Manufactures recommended pressure is 29psi (I have 16 inch spike lines with 205 section tyres), but that's the max I find bareable. I think because they are low profile there's not much gain anyway. Going to change: • I've got lowering springs to lower the car by 25mm. • Maybe remove the passenger wiper. Possibilities. • Modify the pass side air intake to channel more (pressurised) air into it. • Try to get smaller or more aerodynamic door mirrors. The problem is that it's difficult to get mirror bases for the roadster and the standard mirrors have leakage problems anyway. • Headlight covers from Big performance • Brabus (or other) sideskirts • Going to make small aero blocks to fit behind the coupe hinges Can't do (not worth it ££) • Steel roadster 15 inch wheels with 175/185 section eco tyres. Also try to fit aerodynamic hub caps. • Lightweight seats. Standard seats are 20kg each. x 2 is 40kg. I don’t think Smart ever published a cd figure for the Roadster. I’ve saw 0.41 mentioned for the ordinary roadster, but I don’t know how scientifically that was figured out. I suppose though even with that figure taking into account the frontal area, the cdA probably isn’t as bad as I think it is. I think what’s really interesting is the top speed difference between the Roadster and Coupe ~109 v 112 mph, eventhough the Coupe is 40kg heavier. The Kammback does have a significant effect there. My car, with the 205 section tyres, probably affects the fuel economy as much as the aero deficiencies put together. But financially (and aesthetically) it doesn’t make enough sense to change them for Roadster steel wheels. |
Thanks everyone's replys. I prepared the above post at work!
Mine has the paddle shifters, they are very handy. The Stick shift is hard to get onto at first as I also consider it to be back-to-front. The gearbox can be slow, but if you hit the sweetspot (about 75% of the time), the gearchanges are about half a second. My MPG has been about 52-55 IMP most of the time without trying too hard (I tend to drive economically minded anyways but stick to the speed limits). With my last tank I tried really hard (55mph - 65mph) and got 61 which is only 10% more, but still pretty impressive! I think they are a pretty good little machine for what they are! |
One other thing. What would you consider the US EPA for the roadster. I used the 55.4 UK combined figure and simply converted in to US gallons (~46mpg). However, the EPA for Smart cars in the US seems a lot lower?
http://s3.agedstock.com/vehicles/photos/3405/496655.jpg Quote:
Tonight, I removed the wind deflectors on the top of the windscreen. They're just stuck on with hot glue! I just levered them up with a flat-headed screwdriver and scratched the glue away with my fingernail. I've also removed the passenger side wing mirror, although I've not worked out a way to make it neat yet. I may end up using a piece of 4mm Perspex and hoping for the best!
Good work on the deflectors. Have you noticed any difference in wind noise? I think mine will be coming off tomorrow!
This week I've removed my passengers side wiper and put rain repellant on that side. The rain stays off it ok when you go over 50mph, but beads a lot otherwise. I think my next mod will be mold inserts for the side vents. I'm going to use foil and wrap it closely against the body. Then use packing tape to make the outside part the mold (tape from the door sill to the outer part of the vent). Then use expanding foam in the crevace, building it up slowly to minimise any air bubbles. Hopefully then the outer layer will be hard enough to spray silver (to match tridion), don't know if I'll need any filler on top. Have you any experience with doing this sort of thing? This is the area I'll be filling up, except leaving no vent (actually I will have to do something like this for the passenger's side) http://shop.michalak.eu/images/produ...ages/153_0.JPG |
Also how did you remove it? My mirror base doesn't seem to have any screws. It seems to clip together. I know there were loads of revisions of the mirror bases. Evilution - Smart Car Encyclopaedia |
I didn't read Evilution before removing the mirror but I worked it out just how it's written; two torx screws to split it apart and two more that hold the main mirror part on. I've not split the mirror from the base, just left it open (it's not raining today). It's definitely not waterproof at the moment! One thing I've noticed from driving to work today is that I use my passenger side wing mirror a lot. I'll need to replace it with something. I'll have a fiddle in the garage later and take some photos.
The wind deflectors and wing mirror have resulted in a massive decrease in wind noise. It's very noticable, especially at high speed. I've not had the roof down to check the difference in buffeting yet. I may remove my passenger wiper in a minute - it's pretty useless anyway! I also checked the prices of steel wheels and wheel trims for the ForTwo. 3.5"x15" wheels are ~£31+VAT and 4"x15" are ~£35+VAT. I can get some clip-in wheel trims for £25 and a few minutes with a hacksaw, a sheet of ABS, a craft knife and some epoxy should get me some aero wheels. I was looking at the side of the car last night and there's certainly room for manouvre by covering the vents up. Given that the body panels are all bolt-on, there's scope for building a more aerodynamic bodykit. I was thinking of using my current panels to mock up some rear arches that incorporate creased ttrailing edges and wheel covers. Then, I can get them off and use a vacuum former to make lightweight copies for peanuts and in seconds. I'm going to try out the vacuum forming idea with a panel at some point soon to see how it works in practice (weight/flexibility/price/finish). |
I've separated the base from the mirror this afternoon. I did cut a sheet of 4mm Perspex to size and put it in the oven on a baking tray at Gas Mark 6 until it went floppy. By the time I ran it out to the garage, it'd cooled, so I gave up with that and used the base. Best bet is probably to butcher the base for an improvement. I stuck a piece of gaffer tape on the hole that the cable passes through, being carful not to block the drain hole in the bottom. It should be as good as standard now, just with a little less frontal area.
I also tried to remove the passenger wiper arm but I couldn't pull it off when the nut was removed. I suspect the aluminium and iron have welded themselves together over the last 5 years. I'm not willing to put more welly behind it and I don't have any pullers. Anyway, here's some photos: http://roadster.endurancelay.co.uk/i...ngMirror/1.jpg http://roadster.endurancelay.co.uk/i...ngMirror/2.jpg http://roadster.endurancelay.co.uk/i...ngMirror/3.jpg http://roadster.endurancelay.co.uk/i...ngMirror/4.jpg http://roadster.endurancelay.co.uk/i...ngMirror/5.jpg |
Using the fq101 wheel info FQ101 : Taking Modification to the Next Level and then an offset calculator Wheel Offset Calculator It looks like if you changes to 4 inch rims on the front, the rims would be recessed by 16mm against your spinlines. Rears would be in by 25mm. I think the smart wheel trims look good (and aerodynamic) but are expensive at £25 each. http://i.ebayimg.com/03/!BZzvKUw!2k~...n25T!~~_12.JPG The wiper arms were difficult to take off, I had to get a wiper arm puller from e-bay. Don't think it will ever be worth £10! Must get some pics of my grill block for you. Also I was thinking about the diffuser you mentioned. I think it would make the aero worse. The vacuum it creates would only add more drag. The Chevy Volt aero video convinced me of this. On the other hand, i'm not sure if i'm prepared to add straight edges to the back of the car to help the airflow detach from the back of the car cleanly. |
At least they're recessed, not further out. That can be fixed with some appropriate spacers. I'll get some wheels for the next set of tyres I fit. I'm getting close to needing a new set anyway. I checked my tyre pressures earlier and Mercedes had helpfully dropped them to 30psi at the last service and I'd not checked them in the intervening 6 weeks! I'm back up to 40psi now.
Coincidentally, my wife has just walked in the door with a nice new round steel tray from Ikea. £7. Some measuring will be going on later. A puller will be useful, so I'll get one anyway. I bought some cheap wipers on Ebay and the passenger one is rubbish. The only thing it does is stop the arm scratching the screen - I won't miss it! As far as the diffuser goes, my theory was that it'd minimise the size of the wake by reducing the vertical surface area of the rear. It's all guesswork at the moment. If nothing else, it'll finish off the undertray that stops before the engine. I have a spare carbon boot floor that's going on the Mini at some point and it almost got fitted to the underside of the Roadster this afternoon! I think a few sharp creases on the car may help its looks, especially if I can combine them with smaller wheel arch bulges. One thing I learned today was how simple it is to mould Perspex with a little heat from the oven. |
Pics of my grillblock:
http://img39.imageshack.us/img39/2641/image053dy.jpg http://img39.imageshack.us/img39/ima...jpg/1/w640.png You can't see it very well, but that's the point! Also I moved the number plate up a bit. On a roadster I don't think it makes much difference anyway. I wasn't able to get the deflectors above the windscreen off, they are very stubborn. I'll try to heat it up with a hairdryer at the weekend and try again. |
You really can't see the grille block from the photos - good job! I may follow your lead with the number plate - it's a good solution, I think. I found the best way to get the deflectors off was to push them with my thumb so I could get a flat bladed screwdriver underneath, then gently lever up until they're off. It took less than a minute but then I had to spend 15 minutes scratching off the adhesive with my fingernail.
I've done a frontal area comparison in GIMP of the Roadster with and without wing mirrors. The difference with a double wing mirror deletion is ~2.3%, which should gain me ~1mpg. We'll see the real world results when I have done a few tanks of fuel.
It's funny I just found out the frontal area today from here:
http://www.cartoday.com/content/maga...20Roadster.pdf They came up with 1.93m sq or 20.77 sq feet (x10.76). How does that compare to your figures? |
That thread on TRn is what reminded me to do it! I don't have a figure in square metres or feet. My figures are in pixels!
Got it! Pixels is fine since you're able to get an accurate % difference.
I'm going to remove the passengers side first; not sure if I want to remove the driver's side (eventhough I think I use the passengers more when changing lanes). Also as well as decreasing the frontal area, I'm pretty sure it will improve the cd as well, since the mirrors are aerodynamicaly very dirty and they are in an area of high pressure. Is there anything else we can remove? :-) I must work out the frontal area reduction in lowering my car 25mm. Got new springs partially for looks, partially since they all seem to break and also for a slight aerodynamic improvement! |
There's too many inaccuracies to take this as gospel but it looks to be ~3%, although I don't know if you're supposed to use the area under the car when calculating the benefits of lowering. I did this time, although I didn't when calculating the benefit of removing the mirrors.
I'm very seriously considering putting my passenger mirror back on. I don't feel comfortable with my reduced vision. I keep noticing cars moving into my blind spot, which is now much larger! |
I don’t think you count the area under the car, just the tyres frontal.
Area of 2 205 width tyres lowered by 25mm. 205 x 25 = 5125 mm sq x2 = 10250 mm sq 20.5 x 2.5 = 51.25 cm sq x 2 = 102.5 cm sq 0.205 x 0.025 = 0.005125 m sq x 2 = 0.01025 m sq Total frontal area is 1.93m sq % of original frontal area being removed: 0.01025m sq / 1.93m sq = 0.00531 * 100 = 0.531% I’m not sure if that’s correct, but I suppose there are other advantages to lowering (less air under the car, smaller wheel arch gaps). If you feel not having the pass mirror is a safety issue then put it back on, it's just not worth the risk of an accident. |
That'd make sense, really. Of course, the narrower your tyres, the lesser the effect. I'm on 185 width tyres and considering a move to 135! As for the mirror, I'm going to fit one inside the car and see if that's good enough, if not, I have a reversing camera to fit and my last resort is to reinstate the mirror.
Andy, What about aftermarket mirrors? Auto style do mirror bases for the roadster.
http://www.euraxltd.co.uk/documents/...le_mirrors.pdf The KT16B look v aerodynamic (DTM style), while the KT37 look nice. |
Unless I'm missing something, the compatibility matrix doesn't show a Roadster. I like the F1-style ones though - tiny frontal area.
D'oh! I still plan to try internal mirrors but this could be a good fall-back option.
Just had a read through this thread! I must say Damo I'm quite jealous - a Smart Roadster and a 2.4 JTD Alfa 156? Two cars with great fuel efficiency yet loads of fun and sound great too!
I'd just like to make a few queries/comments on things that have been mentioned so far. Quote:
http://i19.photobucket.com/albums/b1..._582916654.jpg Quote:
http://www.bigperformance.co.uk/imag...hc-clear-2.jpg http://www.bigperformance.co.uk/imag...hc-clear-1.jpg Quote:
I unplugged the fuse to my electric power steering and all i got was a pulled muscle in my shoulder! No mpg gains at all.
ollie |
I bought a suction-mount mirror from the local motor factors and stuck it to the inside of the passenger window. My blind spot is now completely eliminated. When I turn my head to look at the mirror (which is in the same place as before), I can either see a car in the next lane over through the window (peripheral vision) or using the mirror. However, my fuel economy has not improved with the mirror delete. I put that down to driving faster at the moment than I normally would.
Thanks for the pics. It's funny actually, even before I saw the Merc badge in that shot I thought "hmm, looks a lot more Mercedes-like"... I think I still prefer the styling as it is, but I can certainly see how light covers would offer aerodynamic benefits. Quote:
