Old 07-10-2008, 12:29 AM   #1 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Turtle new member 50mpg more to come
95 metro sedan with a 1.0 with 4.39 final out of a coupe. 50.05 mpg last 1k miles. original 1.3/5sp car got 46 mpg. i will install the original 3.79 final ratio trans after rebearing job. Also considering 10 degree advance on stock cam or an xfi regrind, that cam is supposed to be 6 degrees advanced and shorter lift. no aero mods other than the right mirror that was gone when the car was purchased. enjoy this site. Thanks Andy in Oregon
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 07-10-2008, 12:50 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to ecomodder!
Old 07-10-2008, 08:19 AM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Did you do the 1.0 swap yourself? Yours is the first 1.0 '95+ sedan I've heard about. Welcome to the site.
Old 07-10-2008, 08:24 AM   #4 (permalink)
Welcome to the site. Sounds like your well on your way.
Old 07-10-2008, 11:21 AM   #5 (permalink)
Yes I did the swap myself. I am a mechanic by trade. I purchased a 95 coupe with a nose job. All the parts were there, the clutch cable is even longer on the 3 cyl setup. I only had to drill one tranny mount hole. I used the coupe as a pattern, exactly 2" back from the factory 4 cylinder mount hole. I have a 60 mile per day commute, mostly on country 55 mph roads. lots of help from you guys on this page, Thanks
Old 07-10-2008, 09:00 PM   #6 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Glad we could help you save on fuel costs! Welcome
GeoMetroforum.com - got mpg?
1994 Ford Aspire Automatic New member bottonavy Introductions 3 07-09-2008 09:58 PM
New member wwkayaker Introductions 3 07-08-2008 10:03 PM
I'm a cab driver and new member Elliott Introductions 4 07-08-2008 10:00 PM
I can almost taste 50MPG trikkonceptz Hypermiling / EcoDriver's Ed 6 06-26-2008 10:26 PM
Can TeamSwift Member Help Me Out? SirKeats The Lounge 4 05-18-2008 07:03 PM
