Hello from Mobile, AL!
Hello all,
I've got a 1993 Geo Prizm 1.6L with a few mods: -removed 3spd in favor of the 4spd -added front and rear sway bars from Corolla for safety reasons -ebay header due to OEM unit failure(cracking is common) -soon will be lowered using TEIN S-tech springs -2mm wheel spacers all around...just cause -gauge cluster with tach |
Must
add
Top of Page
Garage Add New Vehicle Complete, then Add Fill Up Thats it :) |
Welcome to the forum!
A future addition that I plan is to make a belly pan. I will, however, browse the local salvage yards in order to try and source some OEM type under body panelling that I can make fit to aid in aero mods.
Today I fixed(replaced) the speedo due to a broken trip meter. Oh, and upon inspection I noticed the tires were low @30psi. Inflated them to 38psi. Lastly, I plan on using 0W-20 weight oil. I've used before without any adverse effects on engine performance or noise. Jose |
Welcome from your neighboring state MS!
