EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   hello from Nebraska! (https://ecomodder.com/forum/showthread.php/hello-nebraska-32082.html)
mazda6john 06-03-2015 08:27 AM
Hey everyone! I just started lurking here recently and figured i may as well join. Im trading out my 190,000 1998 Dodge neon for a 2003 Mazda 6i and will be doing some aero mods to it in the intrest of improving my fuel milage as i drive about 65 miles per day for work. Looking forward to talking with all of you!
Daox 06-03-2015 09:04 AM
Welcome to the site mazda6john.
What kind of aeromods did you have in mind?
Fat Charlie 06-03-2015 09:07 AM
Welcome!
I can't stress enough that the first modification is instrumentation. ScanGauge, UltraGauge or just a bluetooth OBD connector going to a phone app like Torque- it doesn't matter. The most important thing for economy is adjusting the nut behind the wheel- all the aero mods in the world can't help you if your right foot isn't using them right.
The good gauges may look expensive, but they pay for themselves fast. A bluetooth connector is pretty cheap and pays for itself even faster- and any of them are going to help any other mods you do have a chance to really help you.
Start a fuel log for the Mazda and keep track, too. Real numbers are always better than what you remember seeing on a display.
mazda6john 06-03-2015 05:51 PM
As far as aero i am planning on extending the factory belly pan farther so it encloses the engine bay and then make one for the rear suspension and bumper. I am going to pick up a bluetooth adapter for the obd port and use the torque app to track realtime milage. I also plan on blocking some of the front end off with blue tape to see what kind of an effect that has on aero.
mcrews 06-03-2015 07:52 PM
Welcome!
Increase the psi in the tires to 40+
See belly pan link in my signature
mazda6john 06-09-2015 08:43 PM
Well i was really hoping to have some first tank results this week but its not looking like thats going to happen. I have 210 miles on this tank and just now hit 5/8. Tank is a hair over 16 gal
Fat Charlie 06-10-2015 07:58 AM
Having results is awesome. Not having to put gas in the car is even better! :thumbup:
whatmaycome14 06-10-2015 03:16 PM
Welcome! I look forward to seeing your results. :)
mazda6john 06-14-2015 10:12 PM
First tank results in! Car got 474 miles on 17.01 gal. Airing up the tires to 50 psi tonight for the next tank. I should add, i drive 5 miles city and 25 miles hwy every day so consistancy is not an issue.
Mustang Dave 06-15-2015 07:59 PM
Instrumentation facilitates the most cost-effective ecomod: "adjusting the nut behind the steering wheel". :thumbup:
mazda6john 06-16-2015 03:13 AM
For me currently its more about testing the mods than actually getting the best possible milage. Using the cruise control is counter-productive to getting the best milage but it is much more consistant than any human so i am using it. I need to get a couple more base-line tanks in before i start with taping or increasing tire pressure. I want to have a solid plot of data :)
Fat Charlie 06-16-2015 08:09 AM
Except your baseline is only going to be accurate if the weather stays the same. Outside temperature is a huge factor, and the longer you go past your baseline, the deeper into summer you get. Turning a page on the calendar is an ecomod this time of year.
