Hello from Sunny VA
Hey all, been lurking for about a week since I got my civic. I'm planning on putting on a lexan (top) grill block, coroplast (or something) bottom grill block and mooncaps, but waiting on $.
I'm also considering putting in some LED Daytime Running Lights, but I have to look into legality and what the current DRL setup is. It's an '09 bought with 16k miles, so my wife won't let me do anything fun like a boattail or skirts. First tank got me ~29 MPG (U.S.) with standard crazy driving, and I started hypermiling in the last 30% or so of my 2nd tank and managed 36.7 (404 miles!), which is a hair over my EPA HWY. My current commute is 70% secondary toll highway (55 mph with one booth) and 30% outer suburbia. Looking forward to what tank #3 gets me. My reachable goal is 45MPG, which gets me under $100 and is also equal to the HCH's EPA Highway rating and better than double what my old Mountaineer gets (although that's before adjusting the nut behind the wheel). I also have a stretch goal - 60MPG. Not a whole lot of reason here, just feels like a good number to aim for. I'll make sure I get some "Before" pics up before I start putting the neckbolts on! Thanks for all the info you guys have put up so far, I'll definitely be stealing some DIY ideas... |
Hi -
70% @ 55 mph and 30% outer suburbia sounds pretty ideal as far as MPG friendly territory goes (depending on traffic). I predict good results :) As for those rear wheel skirts, show this to your wife and see what she thinks: http://img182.imageshack.us/img182/1419/civicqn7.jpg from: http://ecomodder.com/forum/showthrea...irts-3816.html 60 is going to be a stretch with an automatic, but it's good to stretch. Welcome to the forum! |
Thanks metro! I'm sure if I had a couple hundred dollars worth of fiberglass and 70 or 80 hours to kill I could make some skirts like that, but I have kids instead :)
cheap post towards images...
another post...
last one.
I was playing in pixlr, and here's my ideal target car. Blue is lexan, red is cardboard/fiberglass, peach (mooncaps) is up in the air, but probably cardboard/fiberglass. I mostly did a different color there so you could tell it was a cover under the skirt in the rear. I have some experience with plexiglass resin/sheet over cardboard, but I will definitely need to find some 4mm mylar for that smooth finish trick. I have some concerns about the kamm - I'll need to be able to use the trunk. I might do a partial in cardboard with trunk clearance and try a tuft test. http://imageshack.us/a/img155/2245/ecocivic.th.jpg edit: And I did show my wife those pics, and she okay'd them. Thanks metro! |
Testing signature...
(KIDDING!) Quote:
There are other ways to do it that don't involve adding a hinge above the rear glass. More complex, but it's doable. From: http://ecomodder.com/forum/showthrea...ods-20741.html |
And it's ok being loose on the sides like that? Looks like it's just held on with hinges on top and the lynch pins on the trunk?
Copyright ©2000 - 2022, vBulletin Solutions Inc.
