Hello from Sunny VA
Hey all, been lurking for about a week since I got my civic. I'm planning on putting on a lexan (top) grill block, coroplast (or something) bottom grill block and mooncaps, but waiting on $.
I'm also considering putting in some LED Daytime Running Lights, but I have to look into legality and what the current DRL setup is. It's an '09 bought with 16k miles, so my wife won't let me do anything fun like a boattail or skirts. First tank got me ~29 MPG (U.S.) with standard crazy driving, and I started hypermiling in the last 30% or so of my 2nd tank and managed 36.7 (404 miles!), which is a hair over my EPA HWY. My current commute is 70% secondary toll highway (55 mph with one booth) and 30% outer suburbia. Looking forward to what tank #3 gets me. My reachable goal is 45MPG, which gets me under $100 and is also equal to the HCH's EPA Highway rating and better than double what my old Mountaineer gets (although that's before adjusting the nut behind the wheel). I also have a stretch goal - 60MPG. Not a whole lot of reason here, just feels like a good number to aim for. I'll make sure I get some "Before" pics up before I start putting the neckbolts on! Thanks for all the info you guys have put up so far, I'll definitely be stealing some DIY ideas... |
Hi -
70% @ 55 mph and 30% outer suburbia sounds pretty ideal as far as MPG friendly territory goes (depending on traffic). I predict good results :) As for those rear wheel skirts, show this to your wife and see what she thinks: http://img182.imageshack.us/img182/1419/civicqn7.jpg from: http://ecomodder.com/forum/showthrea...irts-3816.html 60 is going to be a stretch with an automatic, but it's good to stretch. Welcome to the forum! |
Thanks metro! I'm sure if I had a couple hundred dollars worth of fiberglass and 70 or 80 hours to kill I could make some skirts like that, but I have kids instead :)
cheap post towards images...
another post...
last one.
I was playing in pixlr, and here's my ideal target car. Blue is lexan, red is cardboard/fiberglass, peach (mooncaps) is up in the air, but probably cardboard/fiberglass. I mostly did a different color there so you could tell it was a cover under the skirt in the rear. I have some experience with plexiglass resin/sheet over cardboard, but I will definitely need to find some 4mm mylar for that smooth finish trick. I have some concerns about the kamm - I'll need to be able to use the trunk. I might do a partial in cardboard with trunk clearance and try a tuft test. http://imageshack.us/a/img155/2245/ecocivic.th.jpg edit: And I did show my wife those pics, and she okay'd them. Thanks metro! |
Testing signature...
(KIDDING!) Quote:
There are other ways to do it that don't involve adding a hinge above the rear glass. More complex, but it's doable. From: http://ecomodder.com/forum/showthrea...ods-20741.html |
And it's ok being loose on the sides like that? Looks like it's just held on with hinges on top and the lynch pins on the trunk?
Sure - ideally it would sit flush against the other surfaces. Some kind of weather stripping would work, if the Kammback structure is firm enough.
(Ultimately it was a moot point for this particular car, since it's being junked due to rust.) |
Yeah I saw that. Shame too, he did some really nice work. You'd think he could chop off the offending body and replace with coroplast
Also, I put my 3rd tank in and got ~38.7 mpg(us), which is 33% over EPA combined! And this is just driving style :turtle:, without even a gauge. I'm starting to think my 60MPG goal is doable, but my first step is going to have to be an UltraGauge (it's half the price of the ScanGauge and doesn't seem to be missing anything I need). [edit]AND It got me over +20%. HELLO HYPERMILER LABEL![/edit] |
Well, you could hinge the Kammback at the rear, so it flips back before the trunk opens up. Or it could be mounted on a slider, so it moves aft permitting opening of the trunk. Or you could make it entirely removable.
Ok. I think I've got an idea brewing...
