Hello from Sweden!
Hi everyone.
I am not new to Eco tune your car or trying to drive fuel efficient :turtle:... I found out of this forum by recommendations on a Swedish ethanol forum. With E85 in your fuel tank you maybe more concerned about fuel consumption because the fact it has about 30% less energy per liter than regular gas. I have several old cars and because of the tax laws in Sweden diesels aren't that economic if you don't drive a lot. My recent commuter car and off course hobby and project car is my Audi, a -96 A4 FWD with 1,8 liter turbocharged engine. Stock power is 150hp. Naturally I have done some modifications sutch as converted the engine for E85 104 octan ethanol fuel. The car runs smooth an good without any sign of hammering, pinging or misfire. But I have some cold start problems. At temperatures of about 15 deg C or lower I have problems starting cold. Proberbly because the cold start program in Ecu is to lean for ethanol. If I floor the pedal when starting things get easier but not easy. I have replaced th injectors with bigger and now recently replaced exhaust manifold and turbo. Just now in testing and trimming in state. I hade som boost problems with the new turbo so I think I had a quite lean run before adjusting boost pressure. I'm now running at 0.9bar (13psi) for safe reason. 0.7bar (10psi) is stock setting. I plan to delete viscofan and power steering and to do some aero mods. Best regards Z |
Hi Zovix,
I assume you've already added block, coolant and/or transmission heaters? I know starting ethanol is tough, so warming things up beforehand can't hurt. Or is your drive long enough to even make it worth the trouble? |
I have 60km one way trip to work so I spend a lot of time in my car, also I live in a little town so I have a 20min (18km) ride just to go shopping. I try to plan to shop on my way home for work but sometimes I'm just to tired so I drive straight home. I am interested of learning more about transmission heaters. /Z |
Welcome to the site. It sounds like a fun project you have there. We'd love to hear more about it as you progress.
I reckon there are all manner of engine and tranny heaters available for snowy Sweden. Shop around. |
Welcome!
Cold just start here in Portugal and mpg already go way down... A grill block and heaters are mandatory to good mpg in Sweden I think... |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
