Old 07-28-2012, 12:39 AM   #1 (permalink)
New member from PA
Im glad I found this site.
I'm currently a student majoring in Mechanical Engineering at PSU.
I was commuting the last two semesters which was 77 miles one way.
Although I'm now living on campus, I still want to learn how to improve my gas mileage regardless of my daily travel.
My vehicle of choice is a a '93 Civic dx sedan, 5spd, 230k on the odometer.
During my long commute I was getting a consistent 43 mpg (speed limits, all unnecessary weight gone, never going above 2500 rpm, 95% highway miles)
Future plans:
- swap in the hx trans I have sitting in the garage.
- find a set of vx wheels (very light)
- possible vtec-e engine install
(I am very fluent when it comes to Hondas and automobiles. Currently own a crx which is strictly for drag racing. 580whp, 135+ mph trap times)
I look forward to learning new techniques and possibly giving some technical advice when needed.
Old 07-30-2012, 01:45 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to the site.
All those highway miles make aero mods your friend! Got any plans in that department?
The VX rims won't make a lot of a difference on a car that's mostly highway driven. Taller gearing is a good idea though (especially since you've already got it).
Instrumentation would make it fun as well - you'll need an MPGuino since you're pre-OBD-II. Instant feedback is what makes drag racing fun. Same thing goes for aiming for better fuel economy.
90civicstdgold (07-30-2012)
Old 07-30-2012, 02:40 PM   #3 (permalink)
My goal is to keep the exterior mainly stock. Possibly a grill block, but that's it
The vx wheels are still lighter than the steel wheels on my car currently.
I removed alot of weight from my car when I started the long commutes (spare tire, tools, fluids) Even removed A/C lines and replaced the under dash unit with a non-A/C duct. In total- 106 lbs of extra weight removed.
The HX trans will be installed in the next few weeks after I gather the funds for a new clutch set.
The vtec-e swap will take place this winter for sure.
Some things Ive considered:
-Wheel bearings with much lower resistance than a stock unit?
-An oil cooler?
-And some type of instrumentation as stated above. I still have to read up on how it works with the OBD-1 interface.
Old 08-21-2012, 08:10 AM   #4 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
do some aerodynamics, and maybe lower the car. Push the Tires up to 44 PSI.
look into a timing advance.
those are a few things of the top of my head.
I used to commute like that for my school in central PA (PCT) every 2 weeks. Too bad I didnt know more about this stuff then.
