EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   Help Building DC Brushed Motor Controller (https://ecomodder.com/forum/showthread.php/help-building-dc-brushed-motor-controller-30821.html)
jback3939 01-08-2015 05:49 PM
Let me start by telling you a little about me. I am currently a student studying Mechanical Engineering. As my senior project I have been tasked with designing, and building a complete electric car. I need help with the motor controller and speed controller. I have a basic knowledge of electrical components but I do not even know where to start when it comes to building the motor controller. The setup I am using is a Brushed DC Motor 24V 750W. Can anyone point me in the right direction. I have looked over the sticky at the top of the forum but I couldn't find where he explained what each component was actually being used for. Any help would be greatly appreciated. Thanks
freebeard 01-08-2015 07:43 PM
I'm merely the first poster to happen by. I made it through the first 4 college terms of M.E., then transferred to Architecture. Outlasted 80% of my class, but then they gave me an elective course.
Where to start? How much is 746 Watts in Horsepower? Designing and building a complete car requires a design brief and fabrication facilities.
It will be interesting to see where this goes.
P-hack 01-08-2015 10:11 PM
build and understand this for starters, it is everything you need in miniature:
https://itp.nyu.edu/physcomp/labs/mo...th-an-arduino/
Eventually you will probably use the transistor to switch a larger transistor, and have to deal with gate currents and whatnot, but this is the basics, including microcontroller programming.
Or delegate it to someone in EE, or spend $30 on ebay for a chinese controller.
Edit, I was stuck on 750watt, you aren't serious about putting that in a car (and are a senior in ME) I hope.
freebeard 01-09-2015 12:48 AM
Hopefully we will know more with OP's second post, but it sounds about right for an https://en.wikipedia.org/wiki/Electrathon racer. They have an about 1 kWH battery.
Lots of opportunity there—they're noisy, hard riding little critters mostly built by high school students around here.
