Old 11-24-2009, 10:11 AM   #1 (permalink)
GoldFocus - '09 Ford Focus SE
NarrowerTires?
I have an '09 Focus that is giving pretty good FE. The tires on it are in good shape with only ~22k miles. It will be awhile before I need to look for new shoes but in thinking of ways to improve economy, I was thinking of switching out to some narrower tires when the time comes.
The stock tires are a 195/60-15. I found a 155/80-15 that looks to be within 2% of the stock diameter so it should work without effecting gearing or the odometer/speedo. The only negatives I can think of is the ride will be harsher and to avoid cornering at high speed with the effective higher profile to width ratio. In the realm of safety, seems like it should be fine?
Any thoughts or advice on what I may be missing?
Doug
Old 11-24-2009, 11:21 AM   #2 (permalink)
I think rolling resistance won't be lowered unless you run them with much higher pressure than stockers. But then, you could just as well pump up the stockers.
Old 11-24-2009, 12:06 PM   #3 (permalink)
Hmmm, that is surprising. I would expect a width difference from 195 to 155 would be notable or significant effect on reducing rolling resistance?
Doug
Old 11-24-2009, 12:10 PM   #4 (permalink)
Depends on the loads the tire sees.
Old 11-24-2009, 02:34 PM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
There will be a small but real aerodynamic benefit from going with narrower tires as well.
See this BMW data: http://ecomodder.com/forum/showthrea...g-cd-7475.html
Will 155's fit properly on the rims (width)?
In "the realm of safety", as you put it, I expect you'll likely see reduced lateral grip in the dry (not certain about wet - depends on many other factors). Whether you're OK with that is up to you.
Old 11-24-2009, 04:22 PM   #6 (permalink)
Potentially braking traction will be affected as well. Not definitely, as other factors will have an influence.
I went from 195 to 185 width on my CRX. The difference seems to be "in the noise".
-soD
Old 11-24-2009, 04:27 PM   #7 (permalink)
I went from 185s to 155s on the Paseo. The change was noticeable at low speeds.
Old 11-24-2009, 06:15 PM   #8 (permalink)
The change of what?
Old 11-24-2009, 08:44 PM   #9 (permalink)
I could noticably coast farther after 'the change' of tires/rims.
Old 11-25-2009, 08:19 AM   #10 (permalink)
Tire Geek
CapriRacer's Avatar
Doug
Doug,
First, a 155/80R15 83S is 4 load indices lower in load carrying capacity. That means that all other things being equal, you will need to use 4 psi more than what is on the vehicle tire placard for comparison purposes.
According to Tire Guides, a book that summarizes vehicle tire placards, a 2009 Ford Focus with P195/60R15 87T's should have a tire placard that says to use 32 psi. Please check the vehicle placard to see if that is correct.
What this means is that even if you inflate the tires to the maximum, the tire has less load carrying capacity than the original tires. Not only is that going to hurt the fuel economy, but it's a safety issue, too. Less load carrying capacity increases the risk of a load related tire failure, which sometimes has tragic results.
PLUS, going down in speed rating (T to S) is also the wrong way with regard to safety.
While the amount of tread rubber is important, there are 2 other considerations for a tire's contribution to fuel economy: The rubber, and the amount of deflection.
As I pointed out above, the lower load carrying capacity means more deflection and worse fuel economy - all other things being equal.
The type of rubber is very important - and probably the most important thing. Tires designed for good fuel economy (like what came OE on your Focus), are going to use types of rubber compounds that give good fuel economy. That is generally at the expensive of traction (especially wet traction) and tread wear (or both!)
Going narrower also means a smaller footprint, and that has implications for traction.
So while going narrower may seem like a good idea, there's a lot of down sides to this. It has to be done carefully - which why you asked the question, isn't it!
The Following 2 Users Say Thank You to CapriRacer For This Useful Post:
MetroMPG (11-25-2009), Swiftbow (11-26-2009)
