Help on controller
I have a P & S controller, on 48 volts now. I will go to 96 volts when I`m done. I can`t get my controller to do anything? It will not run the motor. What do I have to do to get it to work? Thanks Ken
In order to help you out we'll need a lot more detail and ideally a few pictures of your setup.
help on controller
I have the battery pack hook up, the + line goes in to a switch, then into the fuse block, out to the contactor, then to the B+ on the controller then to the motor A1, and the other end of motor A2 goes to M-, and the B- goes to the - side of the battery pack. Then the red wire goes to 12 volt B+, and black goes to ground. And the next 3 wires go to the pot box. I have 3 pins on the pot bot, pluse 2 wires red and black. How do I hook it up? I have pictures, but I dont know how to get them here, DO you? Will this help? Do I have it hook up right? Thanks Ken
Ken, do you know how to attach pictures to email? If you send them to me, I can put them on here for you. The pot box should only get the top 2 wires from J1 on the control board. The 3rd (middle) wire on the control board isn't used with the pot box.
Some of Ken's pictures:
http://www.myphotos.yahoo.com/s/20tfp3ygzhuqvp0fimlx http://www.myphotos.yahoo.com/s/20tf...wg.kJ1ZxR.SxYb One thing I noticed is that PH1 and PH2 holes on the control board aren't connected to the power board. It won't work if they aren't connected. Also, The middle wire of J1 seems interconnected with the throttle wires. Are you hooking up the middle wire of J1 to anything? It shouldn't go to the potentiometer. |
Controller
I fix the 2 wires to PH1 & PH2, And I took the middle wire J1 out. And I hooked it all back up and I still get not a thing. NOW WHAT? THANKS KEN
On the potentiometer one wire should be connected to the center terminal and one to one of the other terminals. Depending on what direction you want the potetiometer to turn. I noticed that the thermister is mounted on the board and not inbedded in the heat spreader. That should not keep it from working but might not do much good there.
Alvin |
help on controller
Good news I got my controller to run today. It made the motor go around and I didn`t even have to push on the gas petal... But the BAD news is I burn up the hole side of the controller bi B- all of the mosfets. Can I replace them and make it work agian? What would make the motor spin with out pushing on the petal? thanks ken
If it is a series motor, the normal connections are:
+ A1 S1>>A2 S2 - (large cable between S1 and A1) If the motor turns the wrong way, connect it this way: + A1 S2>>A2 S1 - Connecting power to A1 and A2 will give power to the armature, but it will not be able to react against the field because S1 and S2 don't appear to be powered in your setup. It is possible you blew out the FETs because of the essential dead short A1 to A2. |
If a mosfet is is dead with a short it will allow power to go to the motor when the contactor is turned on. Even without pedal. All of the mosfets may not be bad. If they are still hooked up they all will show a short. If you un-solder a source or drain one at a time and recheck you can find the bad one. There can be more than one.
HI Icheck my motor and the cable is hook to S1 to A1, and B+ goes to A2 and S2 goes to the controller M-. How do I fine out if there a shot in the motor? Do I try it again when I get the new controller, or do I need the motor check frist? What do I do to keep my batteries good over winter, so they don`t go bad?. THANKS ken
You can check for shorts to the motor case by measuring between the armature posts and the case, and the field posts and the case. You may have some amount of resistance due to dirt, carbon dust, etc, but you shouldn't see a dead short (with all cables disconnected).
While the cables are disconnected, check for continuity between A1 and A2, and also between S1 and S2 to see if something has come loose inside. Sometimes its just a matter of moving brush leads inside the motor a bit to eliminate a short. If these checks are OK, you can test the motor operation using a coule of jumper cables by connecting 12 to 24 volts (part of the pack - just a couple of batteries) where the B+ and controller M- connect to the motor (S2 and A2 on your setup). This will turn the motor enough to show it works, but won't overspeed the motor as long as you use low voltage. Make sure the cable is also connected between S1 and A1 to complete the 'series'. Here is an example video I made a while back - http://www.youtube.com/watch?v=x2LQGPN0CN4 Make sure the trans is in neutral, or jack the rear end off the ground to be safe. As far as the batteries go, use your regular battery charger and give them 30 minutes on charge once a week - but don't boil the water out of them. |
Controller
I checked out the motor, it seams to be ok, I didn`t get anything back on the meter. The motor runs fine on 12 volt. It moved the truck forward about 3 inch. and backward 3 inch. So I think I have things hooked up right. I think the switch in the pot box is bad. What kind of switch do I get to replace it? Or do I just buy a new pot box? And still waiting on parts for the controller. And I`M supose to get some one to look at it before I turn it on this time my wife said. or it all goes to junk. Does anyone live near LOUISVILLE,KY.That can look at it for me??? THANK AND EVERYONE HAVE A MERRY CHRISTMAS AND A GOOD NEW YEAR. KEN
She might be related to my wife. I live in Columbus and can check it out with you. PM me with your phone number if you want to chat it over. Mark Weisheimer |
Hi Ken! Your completed controller will ship by next tuesday. Don't worry.
-Paul |
Help on controller
[quote=weisheimer;209980]hmmmm.......
She might be related to my wife. I live in columbus and can check it out with you. Pm me with your phone number if you want to chat it over. Mark weisheimer[/q |
* The pot box switch probably is a DPST switch, with one common, one normally open, and one normally closed terminal. With the throttle in the off position, the terminals you want to use are the ones that are open (off). These will close (turn on) when you press the pedal, allowing the controller to turn on, and the main contactor to close. (typical setup) If the wires are on the wrong terminals, the controller could be on when the throttle is off, and turn off when you apply throttle. If the switch is wired to the NC and NO, and not attached to the common terminal, nothing will happen. * The switch does not connect in series with the pot leads. The pot leads go directly to the controller, and are not switched on/off. * Some pots have dual potentiometers, or four leads coming out of the pot. One pair will be the 0-5000k, (or whatever your controller needs) and the other will be something completely different. You can verify that you are using the correct pot by simply connecting a meter to the pot wires and running the throttle from off to full throttle. If it is a 0-5000 ohm pot, it won't be exactly 5000 ohms (could range 4,500 - 7,000 at the top end) but it will be in the ballpark. * Another item to check is the rigging of the pot compared to the switch. If the switch closes while there is some resistance on the pot (generally more than 50 ohms), the controller may not turn on. This is because some controllers have a safety system that won't allow the controller to turn on with throttle applied so the vehicle doesn't leap forward unexpectedly. To prevent this problem, it is a good idea to setup the pot box with a bit of dead band that allows the throttle pedal to move a bit after the switch comes on, but before the pot gets into control range. If this dead band is too small, the controller may not have enough time to boot before the pot box kicks in, triggering the high pedal disable safety. If you have a bad wire or corroded connection, the wire from pot to controller may have enough resistance by itself to make the controller not work. * Aside from the large HV cables, many controllers work with three small wires to the controller - processor power, and two pot box wires. These usually operate at the same voltage as the HV pack. Your controller appears to have five wires - Are these connected to the proper component/source? Putting power or grounding one of the pot box controller leads may cause problems. Since your controller has five small wires, (two of which appear to be processor + and processor -) it may have a controller processor that doesn't use the same voltage as the main pack. Are you feeding the controller processor with 48 volts, when it is only rated 18-24v? Or conversely, are you feeding it with 12 volts when it needs 48? |
OK, got the number. You might want to edit it away now...Don't need a spam-bot putting you on a gazillion auto-dialers!
I called Ken and we talked about a couple of the things that we are going to look over. With this controller, the electronics are powered by the 12v aux battery. The electronics MUST be turned on first, and off last. So, we'll confirm that the the electronics get their +12vdc and after that, the pre-charge is enabled, and finally, the main contactor. For shut-down, we'll make sure that the contactor is turned Off first, that the pre-charge is off, followed by the electronics. We're going to go over as much of the total wiring as possible too. I believe he is running a prestolite motor, and I am familiar with that motor as I have one in an old school Honda Civic wagon. So, we'll run down the list as we go along and see if we find anything that needs done prior to installing another controller. We'll be doing this mid-week, and we'll update to the post after we're done. |
I went to Ken's yesterday. We had waited until he had obtained a DC-DC converter to keep
The Aux battery charged. At the end of the day, Ken was driving his truck in his drive way. We found a bad pot in his pot box, so he replaced it and we adjusted it for full range via the pedal. Then he added a 75 watt household bulb for pre-charging. Last, he installed the controller and we tested it good. Looks like there is another EV on the road now! |
Oh heck ya. I thought it smelled a little fresher outside when I went for a walk. I thought it was just that I already had my monthly shower.
