Help this eco minded girl modify my Highlander Hybrid
I'm not a big car girl but I want to learn as much as I can. I have a 2007 Highlander Hybrid that I love and I'm really interested in making it even more efficient. So many of the mods and ideas are for the Prius. Has anyone done work on a HH that can share ideas with me?
I'm thinking of starting with the moon disc hubcaps (seems like a relatively easy first project!) but please talk to me about things I can do to improve my fuel efficiency and aerodynamics in my HH. Be patient with me, I may have to go google a whole lot of terms and parts to learn what they mean/do. Thanks in advance! |
Welcome to EM!
I think even easier than the smooth wheel covers, would be an upper grill block? If you try it out with just tape, or some Coroplast (corrugated plastic board that all the lawn signs are made from) and tape/cable ties. Can you post a couple or three pictures of your vehicle? Ecodriving is the least expensive thing to do, for sure -- I would suggest starting a fuel log here, and learn as you go. Check the list of tips. |
You would be well advised to buy and instal a scanguage II so that you know what is going on with the highlander while you are driving, unless,of course, the highlander already has a full dash display... It also helps you learn what are the consequences of deferent driving styles... knowledge is power!
3 Attachment(s)
Thanks, I appreciate the ideas. I've been reading the tips on ecodriving tactics, paid way more attention to my driving today. Kind of amazed at how often we are pressing on the gas when we don't need to be!
I'll look up that scanguage II, I bet that tells me more than the dash readout. I've uploaded a few pics. Keep the ideas coming. I can't picture how the lawn signs over the grill block would look, I'll see if I can find pics of other people that have done that on here for a reference. Thanks again! |
You can use actual lawn signs (and paint them black), or you can use black Coroplast (often the best source is from a sign shop) -- but your grill looks easy to try out a temporary block with black gaffer's tape, or Gorilla Tape. I'll bet you can block off the top two sections, and maybe all of the upper grill? If the dash doesn't already have a temperature gauge, then the ScanGuage II can provide this.
It's too bad the rear "spoiler" juts up (slightly) above the roof -- it would be much better if it dropped slightly down, instead. What is your tire pressure, and what is the maximum pressure written on the sidewalls? Have you started keeping fuel records? This is certainly where you be able to tell how you are doing. And yes, ecodriving is a process of learning how to use just enough throttle to get where you need to, and how to avoid using your brakes on a regular basis. Does your Highlander have the 'B' mode on the shifter? You can use that to slow down and get regenerative braking. But coast when you can, and when you can carry speed. |
As an interesting sidebar, at Toyota's website,
the base model Highlander's MPG is 20/27, (other Highlander packages get 18/24) the Highlander Hybrid's MPG is 27/25. What's up with the hybrid's lower highway MPG? |
Just curious: Someone was asking me for a recommendation for a hybrid for serious off-roading. Any opinions?
The new Prius (T3) is also better rated in city vs. highway cycle fueleconomy.gov ratings .................................................. ............................................ Quote:
