EcoModder.com
-   -   Help with gearing (https://ecomodder.com/forum/showthread.php/help-gearing-37824.html)
IsaacCarlson 09-09-2019 10:43 PM
Help with gearing
I'm having a hard time deciding what to do.
I am finally making my truck 4wd, but the donor has 3.55 gears and I have 4.10's after getting a new axle several years ago.(4.10 was the only thing available) Do I swap in the 3.55 gears or buy a matching 4.10 for the new front end?
I currently have the m5odr2 which has a fairly high low end and not much overdrive. The 4.10 helped with the low end, but hurt me on the top end. It pulls like a dream and it's nice to not down shift for most hills when loaded, but it just feels like it's screaming along at cruise.
The donor has the zf5 which has a deeper low end and higher top hole. I think it would be fine with the 3.55 gears because it has the deeper gears on the bottom to make up the difference. The extra overdrive would be awesome too.
It's going to be ~20% reduction in wheel torque in the top hole with the 3.55/zf combo by my math. About 14% with the rear end and another 5% with the overdrive step. I'd be shifting down on hills for sure.
I normally weigh ~12,000 lbs loaded, so that lost torque will be noticeable.
Shifting down to 4th for hills will put my rpm's higher than they would have been with the 4.10 in 5th gear.
M5od/4.10 is 2100 in 5th
Zf5/3.55 is 2270 in 4th
I'd like to get my rpm's down and get a few mpg back, but I don't want to lose my grade pulling ability.
What would you guys do? Any advice? Feel free to toss ideas around. I'm not buying two new 3.73 gear sets, so that is out.
:confused:
Ecky 09-10-2019 06:26 AM
I can't speak for towing, but in most vehicles, going with taller gearing improves economy all the way up to the point that you can't maintain speed in that gear anymore - and then you just downshift.
In my car I picked the tallest 6th available from any model (usually paired with shorter final drives) and had a custom final drive cut which was 30% taller than anything OEM. I also upsized my tires slightly. Going even taller would help even more, but my low gears might need to be changed so they're a little closer together to keep it fun when I want to waste fuel.
me and my metro 09-10-2019 11:12 AM
You are in the position to test what you need. Continue with your conversion, install the ZF and drive with your load. I think you will like the 4:10s loaded with the small engine. I have 4:56 gears in my NA Diesel pickup with a 30% od and it is fine on the highway towing. I have driven this same engine/trans with 3:73 towing and it was in direct all the time. So no fuel saving loaded.
oil pan 4 09-10-2019 06:02 PM
Ford went standard with 3.55 gear sets a few years ago.
But I think 4.10 is still the ultimate towing package.
cRiPpLe_rOoStEr 09-10-2019 06:52 PM
I'd always prefer to get front an rear differentials matching the same ratio, but some wider gear spread is also desirable. Either a 6-speed with a wider ratio, or a supplemental overdrive, could be a good measure to balance both priorities.
serialk11r 09-10-2019 08:09 PM
If you have an Insight, sure :P
When I had my FR-S with an instantaneous mpg gauge (which I used to mentally calculate the load from), I realized that it is really easy to step too hard on gas in 6th gear and run rich.
In a heavier car (for the gearing/torque), this can be a huge problem. Cruise control would make the car run rich up hills!
I still like tall gearing, but you definitely have to be on top of your shifting game and have a careful foot to get the best out of it.
royanddoreen 09-11-2019 08:09 AM
might be a crazy thought, but can you match rpm by having two different o.d. size tires from front to back?
Ecky 09-11-2019 10:02 AM
I found something quite interesting when poking about with Honda's K series. Turns out the engine in cars like the older Type R, TSX, Civic Si, don't actually go rich even at WOT. That's true of most stock engine maps. Honda chose instead to pull timing to prevent knock. Now, admittedly this also has a fuel economy impact, since your peak cylinder pressure is farther from optimal crank angle.
I have no idea how Ford chose to handle WOT with the straight 6, but food for thought, you want to be in the engine's most efficient range as much as possible, and its lease efficient range as little as possible. If there's an issue with enrichment or getting at a high enough load that timing is seriously retarded, there's always a downshift.
My 2 cents.
Big Dave 09-11-2019 12:11 PM
You gotta match ratios axle-to-axle. Otherwise you destroy the transfer case within a few minutes of engagement.
aardvarcus 09-11-2019 02:58 PM
You can't talk rear end gear ratios without talking transmission gear ratios. The internet is telling me your transmission has 3.9:1 first and 0.8:1 fifth. Picking your rear end ratio to me is really about a trade-off in first and fifth, would you rather have a lower first or a taller fifth. For any other gear, you could just shift to alter the ratio but you can't go lower than first or higher than fifth.
In my experience I would prefer the 3.55 to the 4:10, as long as you don't think you will have a problem in first taking off loaded. With 3.9:1 first I don't think you will, but you know your engine/torque curve better than me. The fact that your donor vehicle is set up that way from the factory tells me it can't be that bad.
I would much rather have to downshift on the hills than to be downshifted all the time. To me a truck that drives around all the time in OD and never needs to downshift for steep hills is over-geared IMHO. It also seems you already own the matching 3.55 and would have to purchase the 4.10 front, so I would try it out before spending additional cash.
serialk11r 09-12-2019 12:44 AM
Correct, many older engines did not run rich at WOT until about 3500-4000rpm. Stepping hard on the gas is less detrimental in those cases.
Everything newer though does go rich. All of the Toyota [A/N/Z/G/U]R engines do for example.
Ecky 09-12-2019 08:28 AM
I'm getting a bit off topic here, but this is in reference to engines as new as engines as new as 2015. I don't know if the revisions which got direct injection started going rich under heavy load, but that would be in the last 4-6 years.
IsaacCarlson 09-12-2019 09:23 AM
My brother said the same thing about already having the 3.55's. The donor zf trans has a 5.72 1st and .76 od with a 5.24 reverse. Either way I get the best of both ends, lol. 3.55 it is. I'll have 5 gears in the basement after the swap if I need them.
aardvarcus 09-12-2019 10:46 AM
Yea with a 5.72:1 first I would use the 3.55 without question.
I put a modified NV4500 in my 1994 K2500 Suburban which has a 5.61:1 first, the suburban came with 4.10 gears and first is way low. I will be swapping in 3.42 gears (tallest I can swap in factory diffs) when the project gets to that point.
cRiPpLe_rOoStEr 09-12-2019 11:18 PM
Makes me remind those Japanese and Korean cab-forward minitrucks with smaller rear wheels and a higher differential gear. But those were used in order to allow a lower boarding height, not to compensate for mismatching differential ratio in a 4WD version (which I have only seen on SRW and matching differential ratio). AFAIK the only 4WD applications with wheel sizes mismatching between the front and rear axle are agricultural machinery.
ProDigit 10-07-2019 10:31 PM
I think, if you're using 3.55 gearing, it's easy to just shift up one gear if you really need to, and get the same towing as the tow package in final gear.
You can also play with about 12-20% of gearing difference, by adjusting the tire circumference.
diesel_john 10-08-2019 09:10 AM
My vote would be for the 3.56 rear. And 3.55 front.
I assume the two speed transfer case will take care of the torque needed in 4wd.
I tow in direct drive in the trans. its less efficient than over drive but less heat in the trans.
I am all for overdrive under light to medium loads but it is not quite as efficient as the numbers would suggest in my experience with heavy loads. IMO the gears are there to use and take strain off the clutches and engine. But i like to shift.
I also like manual unlock front hubs for maneuvering in close quarters while needing low transfer case. That way i idle in low low and back trailers with my front hitch.
ocnorb 10-08-2019 09:25 AM
You don't say what motor you have (unless I missed it) or how heavy you need to tow.
I have a '94 F-350 diesel with zf5 and 3.55 gears from the factory. I can pull up to about 20k gross comfortably (with intercooling) and love the gearing when unloaded. 2000 rpm @70mph. These motors will pull all the way down to 1200 rpm. I do wish my zf5 had the lower first great sometimes.
MeteorGray 10-10-2019 09:44 AM
My towing rig is a '96 F250 7.3L diesel automatic with a 3.55 rear differential. My travel trailer weighs in at 6000 pounds, and the truck at about 9000, totaling about 15,000 pounds which is the listed GCVWR for the 3.55 gears in that year.
If I towed more weight I'd have opted for the 4.10 gears that were available that year; but I don't, and I didn't.
My normal towing speed is about 60mph, which equates to about 1500RPM. I normally average about 14MPG towing.
When not towing on the highway, I can get about 23MPG at 55 MPH and 21MPG at 70 MPH.
I have all the power I need in the hills and dales, so am happy with the whole setup, which I've been using since I purchased it new in 1996.
IsaacCarlson 11-09-2019 07:00 PM
A little revival here...
I can't use the 4wd front axle. It's a leaf spring and the knuckles won't fit on my brother's coil front axle. I can't use leaf spring because my snow plow is mounted where the leaves/shackles go. I guess it's more 2wd this year until I can find chevy knuckles.
