Help on running a second deep cell battery
I need some help to build a system (secondary deep cell battery )that can be charge from my alternator sometimes in case of a "long distance commute", but most of the time "short commutes" it will be charged at work and home. Electronics are my weak point so some advice would be great!!! |
Sounds like you need a wall charger and you alternator controlled on a switch. Other than that you just need a deep cell battery that fits under the hood or do a relocation to the trunk. Think there are a few threads on controlling alternator on a switch, I don't know how to do it but have seen posts about it.
Just double read your post and noticed you want to do a backup battery. Easiest way would be just run a deep cycle alone with no "regular" battery serving primatry duty. |
