Here is my front lower pan on Dart
Most recent project to Dart was full airdam and lower pan.I used a modified Chevy pick up truck air dam and constructed the frame from ABS plastic . I will post photos as soon as I am allowed by forum protocols.
I am eager to explore further possibilities, and learn from you guys. Lots of questions. Sam |
This is an attempt to post a photo. Lets see if it works.
http://i881.photobucket.com/albums/a...6/CIMG0761.jpg http://i881.photobucket.com/albums/a...6/CIMG0757.jpg View unpainted and after paint. I made this dam and pan as a result of things posted on this forum. Sam |
any tests yet?
Nice work!
Love them colors.
What engine? Slant 6 (170, 225 cid) or small-block V8 (273, 318, 340, 360 cid)?
Looks good. It's nice to see someone applying these ideas to older iron. I am into older Chrysler products and will be watching with interest
Travis.. |
Yep. 225 slant six bored 30 over to 230. For all the weight it is a rather small inline six for its era. No, I have not tested the lower pan, and know of no easy way to do one. The ecu on the EFI which is on this engine will not do the math to report mileage, although it will report injector open times in ms. I suppose if I did the math myself I could come up with a conversion table, and watch the injector open time to get real time feedback, but nothing cumulative. I had a Miata with a scan gauge on it, but that stayed with the car when sold. It would be interesting to know if anyone with Megasquirt has made an interface with a scan gauge to read real time and accumulated mileage figures.
Injectors are 24lb/hour. I would have do some research to figure out what that means in gallons. Does anybody know? Then I would have to figure out how much fuel went through the injector in 1 millisecond. The transition time on the injector would muddy that picture a bit at low rpms. Any thoughts on that one? I think I can lower car a bit more, but would have to cut a bit off the bump stops to make that work. I would do that in a heart beat, and probably will. Sam |
OpenGauge / MPGuino FE computer - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com |
Thanks. I quickly scanned the many posts on this link and am interested. However, Firefox would not let me access the link that offered the device for sale. Can you give me a quick sales pitch, or maybe an e-mail address? This car is not OBD anything. I would likely have to get the tech guys who put this together working with the open source guys that developed Megasquirt to see how we could get them to talk to each other. The output from the ECU is an old parallel port with connector. I use a USB adaptor to connect to my laptop. Getting the fuel economy module talking with the ECU would be over my head IT stuff. I am open to paying someone to help.
Sam |
Nice adaptation, love the splitter too.
The MS can log fuel usage (and really anything else you want). There are a number of ways to view that data... laptop/phone/etc. Here's one to get you started. msDroid :: MegaSquirt configuration and log recorder / viewer for Android If you check some MS forums, you may find some better options.
I love that you have the slant running with an MS. I started one as a project in the past, but never got too far. Had a '71 and a'74 Valiant. I don't think either of them saw any higher than 18mpg and any lower than 17mpg. |
Looks mighty fine to me! I especially like the tin work under it
Love it and the Dart
Thanks for the nice comments.I have been watching the progress of the blue tooth android connection for awhile. I am afraid the droid/blue tooth connection is over my head at this point. From the FB comments I read I am not the only one to feel this way. I will look into it further though. Thanks for bringing it up.
For now, I would like to refocus the discussion on the airdam theories floating around. I will get a thread started, or look for an existing one on the fuel usage monitoring on Megasquirt. I got the idea for the front pan and splitter from a British publication that is on line in which a fellow added a pan to an early Prius and saw a significant improvement in actual mileage measured. After reading on line a bit I could see that with the extremely dirty lower area on these old Mopars, a front air dam was kind of a no brainer. The bumpers are high, and there is much stuff hanging out down below there. The radiator core support, K member, and sway bar all create quite of a bit of obstruction. So I designed a metal pan to cover the area between the bumper and the radiator lower edge, which drops down at about a 15 degree angle, and then designed the air dam to hang down as low as the lowest part, and finish it off below with a level, full lower pan. A splitter apparently is designed to create down force at speed. This is a feature I do not really need, but thought it looked cool, and likely is not hurting anything. The finishing touch is the tabs I added in front of the wheels. Research shows that this sometimes helps, and sometimes does not help much, but I decided to add them just in case. Now I wish to improve the frontal area a bit more by blocking off the radiator when not needed. I would like to automate it somehow, but may end up simply putting a louvered vent cap of some kind in there and working it with a manual cable, or motor actuated with a switch. This would help with quicker warm up if nothing else. Any ideas along those lines, or links to pages where this has been done or discussed would be eagerly read. Thanks again. I have been reading other threads here and soaking stuff up as much as possible for a newcomer. Sam |
