Hey - Young vanner here
Just saying hey to everybody, im 21, out of KY, here (finally) because I bought a giant 87 chevy van as an impulse at an as-is auction. i just wanted to put some speakers in it, but everything i did beget something else and now im building up a custom interior from pretty much scratch. Upon finding out she gets 11 mpg from an old small block (surprise!) TBI 305, im afraid the same phenomenon is happening under the hood. I dont have the capital or expertise for an engine swap, but i refuse to believe some careful tuning and the right parts cant make a roadtrip cruiser out of the 305 yet. You don't have to read anymore. Very exciting to have finally stumbled here!
For those going on, might as well kill two birds here: Without the obvious solution of reducing displacement or going diesel, what's next best? Reducing rpm to as low as possible? Reducing throttle restriction? More power/taller gears? Lowering peak torque rpm? How much hp do i really need to keep this thing at 70 mph? What components determine rpm operating range? What's the tallest rear end I can safely put on? *sigh* so many questions, so many factors. I care about FE/gradeability at 70 mph, and only 70 mph, and for that narrow application im sure there's a hard fast answer I just havent found yet. At any rate im learning new tricks here by the minute (WAI? Boattails?? Wow!) on topics where information is ordinarily very very rare. Keep up the awesome work everyone! |
What tranny does it have? fueleconomy.gov it looks like with the 305 (5L engine) depending on your tranny your EPA mileage will range from 12-14mpg in the city and 15-18 on the highway, so I would start out getting your vehicle to stock EPA, then improve from there.
I would start out by finding the narrowest tires you can get,and I suspect that narrow (light) rims for a van like that are going to end up being steel, just because alloy rims are tend to be wider, also if you get under your van you are going to notice the whole underside is not smooth to say the least, but I suspect that with the frame of the vehicle building an under tray should be easy and that is going to help your highway mileage. |
same as ryland said make a belly pan, i have a huge list of stuff that i posted on a thread about an rv earlier, it all pretty much carries over to vans
*grill block *belly pan (you can go to rv parts stores and buy big sheets of fiberglass) *tire pressure *electric radiator fan *the skirt thing under front bumper *skirts around sides *new shock absorbers/ springs *make an angled roof extension (not to sharp of an angle) along the lines of a boat tail *get rid of useless mass *switch to lighter materials (heavy wood counters -> fiberglass counters carpet -> vinyl) *remove radio antenna (relocate inside of body) * DO NOT REMOVE MIRRORS!!!!! they are extremely valuable, just make aero housings for those i cut some of the things from my list i posted for the rv as i dont think they apply to your situation here is the link to that post if your interested http://forum.ecomodder.com/showthread.php?t=1051 also in that thread (i think its the 3rd or 4th post) there is a pic of a van done by nasa, it has some really good ideas. when it comes to efficiency of the motor, remember it is one big air pump, remove as many restrictions from the intake and exhaust as possible (switch to a high flow cat, ditching it really is not all to beneficial) also do all the regular maintenance (spark plugs, fuel filter, air filter, 5w20 oil) anyhow hope this helps some John |
Might be more work than what its worth but there was a 305 offered with MPFI. Figure if you could get the intake, injectors, computer and the rest of the stuff required that could net you a nice gain right there vs your current TBI setup.
A rambling response
Thanks for the quick responses, all good ideas... THM350 or THM400, either way a 3-speed with no overdrive, which will obviously have to go. I'm probably wildly short of stock mpg because of a crap air filter, crap gaskets, exhaust corrosion, and excessive drag (especially from brakes). I'm not at all worried about pulling it back up to 15 mpg, this is all to get me to 20. I do like the idea of bigger, thinner wheels, they just take a backseat to the challenge at hand. I'll have to look into whether an undertray is easier/appreciably more effective than a front air dam. Or you could tell me, haha.
Johnpr you are certainly on point with all your ideas, excellent list, and indeed I'm sure most would pay for themselves. My to-do list grows exponentially. Do you say new shocks for the lowering benefit? If so I would expect the relative benefit of a front air dam or especially an undertray to decrease. The rest of the recommendations, intake/exhaust and EFI, highlight a particular problem I'm having with spec'ing the engine. If it's already of sufficient torque to move the van, any breathing and thus hp gains from exhaust will seemingly encourage burning more fuel with little added usefulness. Furthermore, the stock exhaust manifold lends itself to low-end torque and vans seemed plagued with ill-fitting headers. With the intake, I don't want to upgrade the carb, im sorry i meant throttle body, only to have the engine always choked off by the throttle plate anyway. Finally, EFI is tough to justify because of the narrow application. In short I can tune the carb, im sorry throttle body, for my application and the advantages of an adaptive EFI system all but disappear, save for cold temperatures and the minor losses inherent in only using one injector. Thanks for the thought-provoking answers, you guys are awesome! i really do try to keep these things short. If im wrong about anything, and im sure i am, do tell me. Thanks! |
on the shocks, its not because of lowering the vehicle, you are right that it would decrease the value of the airdam and undertray, the reasoning is that as shocks get older there effectiveness decrease allowing excess movement which can rob your vehicle of power (shift in weight distribution when accelerating, turning corners etc) long story short, a stable vehicle gets better mpg. as for increasing air volume in and out, it doesnt necesarily increase fuel consumption, if you were to take an air/fuel meter and check your ratio you might find that you have a rich mixture, this is very common on older american engines and can be improved by decreasing the restriction on the airfloe into the engine (also a smoother flow increases atomization of the fuel allowing a more efficient burn process) as with the exhaust it just decreases the work the engine has to do to "exhale" but the biggest thing that is an engine specific affect is the maintenance.
anyhow, try the other mods first, those are for the most part the bigger helpers, the intake / exhaust stuff is all afterthoughts :) happy modding john |
Keep in mind though, that hp gains aren't always good, most of the mods that increase horsepower do only that, and decrease efficiency for power.
There a thread with significant info about exhaust tuning. Bigger free flowing exhaust, or none at all can actually HURT your mileage. your exhaust basically gets turned into one big muffler, not in that it muffles sound, but how one causes exhaust to bounce around into other exhaust sounds, canceling the sound. too big of an exhaust actually can hurt performance AND efficiency, but in order to get the full just of what I'm trying to say, you'll have to find the thread. Also, you only use about 20 HP going 60 down the highway. so 70 wouldn't be too much more. I don't think power and efficiency go together, and that torque is more important that Hp. generally, smaller exhaust=more low end torque, but less power, and larger exhaust=more power, but less low end torque. your gonna wanna look HEAVILY into aero if your gonna wanna have a van do 70 and get good mpg. look up basjoos's aerocivic, you can find a lot about aero from there. I have more, but i gotta run. |
Welcome to the community.
The best thing you could do for the van is put a water bed in the back. |
That high-top isn't doing you any favors when you're driving; it's only when you're parked and moving around inside that it is any use. If you expect to mostly use the van for going places, then consider switching it to a lower-height, smoother model, preferably one with a nice, long taper to the rear.
Look really hard at changing your axle ratio. If you're not a speed demon and willing to drive conservatively - and being here suggests you are - and don't do any towing, you could switch out to a pretty tall final ratio and really slow the engine down. Barring that, it shouldn't be too hard to find a somewhat less prehistoric 4-spd auto that'll hook up to your 305. One with a lockup torque converter if you can find it. What part of KY? Did you go to the Farm Machinery Show? |
just to make my stance clear, im not advocating a 3 in exhaust, DPoV is right, too large of an exhaust will harm performance and eficiancy, and so will an exhaust which is too small, its just one of those if everything else is taken care of then make sure that is in order also.
Maybe you could mod your high top to make it a "pop" top that you can lower while driving.
Decreasing that frontal area would give you a measurable gain at the pumps, and it might not have to cost much money, either. |
Hey! like the others I dont have much time here, but i want to thank you all for the ideas again. a pop top is in my dreams, in the meantime im trying to figure out a way to get the most out of the extra height (storage, dance parties...). if i had a waterbed sitting around i would seriously entertain it. i have. little tacky though.
finally, i am absolutely changing the rear end, but because it means a compromise in acceleration and taller gears are a little more flimsy i'm looking at wheel size and OD gear ratio first. Then final gear to get the engine to the target rpm at 70mph, yes? Whatever that heck that rpm might be. johnpr, on point with everything as always. thanks again, i love the ideas! i'll have to throw in a picture of the frontal area for some laughs. |
thats great, i didn'e even think about the fact there arent any pix in this thread. looking forward to seeing your ride
For all intents and purposes, it looks like this but white:
http://ppgmedia.buysell.com/ppgphoto...87-display.jpg |
Welcome!
Without too much effort (i.e., getting it in good running order), you should be able to manage upper teens on the highway. My girlfriend's parents have an old GMC conversion van that averaged 18mpg when they drove from NY to Texas last christmas, so low-20s is probably within reach, really. |
Dude! I love vans! I had a few "Hippy Vans" back in the day. I had a 1973 Dodge Sportsman and a 1993 Chevy similar to yours.
I know you wanna do up the interior, but that will add a lot of weight and sacrifice some MPG's. My 1974 Dodge was a cargo van with no windows (except the small teardrop side windows) and for the interior, I laid plywood, and then that egg foam on top. After that the entire interior got 4" dark blue shag carpet including the ceiling and walls. It was like climbing into a big furry cave. Ahhh, the memories.......... Anyway, welcome to the forum! |
Welcome!
Less weight will help, water beds not so much. If there are a bunch of back seats that are rarely used remove them, it will help, and those running board/fender flare thingies don't look very aero, and it might help to remove them too. If the speed limit on the freeway is 70, then get in the right lane and go 65 or even 60 it will make a really big difference. Speeds over 60MPH really start sucking gas. Later, Allan Greenblazer |
Mumblings incoherent
I forgot how much fun it is on this forum!... and looking back everyone had some excellent ideas on economy. Mullet, that is what i ended up doing with the floor, but rubber-backed indoor/outdoor carpet instead of shag, and indeed that was the gist of the original flooring by the conversion company. Killingjams, I've had other people cite that exact number. That tells me that 18mpg is the glass ceiling for the 305. Not my 305, im using seals that were supposed to be replaced 100,000 miles ago. Increasing beyond 18 will likely involve either running a smaller engine and some clever gearing, or a smaller throttle body, new seals, and some clever gearing. Either way reducing power in some way other than throttle plate restriction.
The points of resistance I encounter from other people: in the case of an engine swap, a general adversion to running an engine (even a smaller one) at higher rpms, which people universally explain as "the engine has to work harder." Every engine has it's "sweet spot" and running it faster than that will decrease efficiency, but by how much? Enough to be outweighed by the fuel economy benefit of smaller displacement? In the other solution, of a smaller throttle body (the van is TBI), the AmeriV8 crowd pans the 305. If it is inferior to the 350 in every way, why is it in my van? Either way, I've never seen a larger-displacement engine get better economy than a smaller one. Ever. Rambling. My plan is to figure out how much torque I need to keep this van moving at 70 mph, and then go to GM and other manufacturers and get this magical graph im pretty sure doesnt exist called "torque vs. fuel consumption." Pick my favorite. Which will probably be a 2-liter or something that gets my van to 70mph in 5 minutes flat. This post is already too long, but I'd like to quickly address weight. I think it's the "white pages" from Cummins, a file online that talks about improving efficiency in tractor-trailers. On the interstate, which is my ONLY application, they say losses boil down to drag, engine inefficiencies, and rolling resistance. About 65%, 15%, 20% respectively. Weight would only affect rolling resistance, a little. Just pump up a couple more psi or something, we're talking maybe 10% of 20% here, because and only because i am not accelerating on the interstate. Stop and go in the city? All bets are off, but for the non-accelerating interstate cruise roll out the waterbeds, weight doesnt matter. Otherwise these 80,000 lb semis wouldnt be getting 10 mpg. Grill block and front air dam will probably be it for aero mods. 70mph is my challenge, Green, I can't compromise on that! Thanks allbody! |
More weight
Ah, thanks to Bearleener's "back of the envelope" calculations I can see we're talking a bit more than 10% of 20% here, but not by much. The "wind tunnel" thread talks about how, at a constant 60 mph, a reduction in Cd of .01 is the equivalent of removing 220 pounds from the car. I would expect that figure to exceed 300 pounds at a constant 70 mph, and nothing I am doing to the interior is in that magnitude.
Alright, no one closed my thread so let's necro it. Thank you, incidentally, to all the amazing users on here: the time and effort the users put into this site have always seriously impressed me.
I still have the van (not to mention my login info). I can't bring myself to sell it - too much faulty "customization" anyway (did you know splicing starter wires together with electrical tape lasts you about a year?). Here's the short story: High-top conversion van (7'7"). 305 V8 TBI with 3-speed automatic. 9/13 (EPA is 13/15), my record for a tank was 15.6 (all night through Missouri). Here's an emissions report (lol): HC GPM (gallons per minute?) = 5.78, Limit = 3.5 (Unburned fuel) CO GPM = 71.5, Limit = 30 (Air/fuel mixture too rich) CO2 GPM = 527, Limit = None NOx GPM = 1.4, Limit = 5.5 (High temperatures) A replacement van on my budget is 18mpg, so 20 with my driving style. Surely for that kind of money I can do better. Within the next 6 months I'll be putting together a budget (~$5000) and strategy for tripling my gas mileage while still using this thing to move. |
