Hi Guys
Hi Guys.
I started Hypermiling a few weeks ago with my 81 rabbit diesel 1.6 na and had some decent results. 416.6 miles used 7.4 gallons or 56 mpgs. these arent hyw miles but the back roads in east texas. Average Speed maybe 40 mpgs, never going over 50 and more often than not onder 40. I started doing engine off coasting this tank. the car has a 5 speed in it and i try to get in it as fast as i can on semi level ground or stay in 4th and just touch the gas peddle for the hilly areas. I saw where Project Sipster got 84 mpgs with some areo mods and swapping the engine. Im wondering if i do the areo mods but no engine swap how high this thing might get. im no speed demon and am never in a hurry so hopefully someday we will see. My first mod i think will be a full belly pan. i have an cow feeder on the property that has enough galvinized sheet metal on it to cover the belly. I think this will help a bunch since the back end of the rabbit undderbelly can catch a LOT of wind the way its designed. Looking forward to reading more and learning more from the sight. Thanks for reading, Don |
Welcome.
The gains from mode will vary, but they do add up. Smooth wheels and grill blocks are two others you can pretty easily manage that will net you some decent gains. Also, don't forget inflating your tires to the max side wall or even over inflating if you feel comfortable. |
Thanks Jsatter,
The Tires on the car are 155 80 r 13s pumped up to 60 psi. the max sidewall rateing is 44 : ) I will get to work on the grill block. though im not sure how long that would be usable here in East texas were probably a month or 2 from the 100+ temp days again. Thanks, Don |
welcome. i'm from east texas
Hi Jedi,
looks like we have a few east texas hypermilers on the sight. A lot to learn and have fun with. Thanks Don |
I managed to get a low '70's mpg once on a trip eastbound in western Kansas w an
'82 Quantum wagon w the same motor as yours. I regularly got 52-57mpg on roads trips at 50-55 mph. I never got below 46mpg commuting (admittingly 3/4ths freeway), and still go 32mpg. towing a 200# + bolt together trailer w a small motorcycle, and bicycle strapped on for a camping trip in the mountains. Keep up the good work. Is yours a 4 speed, or a 5? |
Hi Larry,
the Rabbit is a 5spd in it. A friend helped me mount a fuel cut off switch in it a couple of days ago as i was getting worried about burning up the glow plugs useing the key for off engine coasting. Im thinking this will ease my mind and ill do engine off coasting more now. You hitting the low 70s once gives me hope that i might can do the same. My last tank was 56.2 mpgs with at the most 60 miles of freeway. I am disabled and havent worked in a long time so most of my trips are within 10 to 20 miles of my house. Doctors, store for food and try to go to my friends once a week just to get out of the house LOL Hopefully this spring i can get to work on some aero mods to help the rabbit cut through the wind a little better. Thanks for reading, Don |
Keep up the good work and start a fuel log so we can keep track of you.
Thanks Dave,
I got the fuel log done. dont know how to get it on the bottom of my posts but its in the garage part of the site now. thanks for reading, Don |
http://ecomodder.com/forum/showthrea...ture-2117.html It's not mandatory though ;) |
I looked up the EPA rating for an '84 diesel rabbit (which I assume is pretty similar to the '81). It's rating is 35 city, 43 highway (38 mpg combined), so I'd say you're doing pretty well.
Looking good, Man. Belly pan is HUGE on these cars. Just the front half will help a lot. Full pan is even better.
Also, you might want to look into getting the first generation Honda Insight tires when you need new ones. They are Bridgestone RE92 165/65R14. They are VERY low rolling resistance. I noticed a very large difference when I switched to them. |
Thanks Euro, Dave and Jethro.
I have been doing physical theraphy and going to doctors appointments all month still have 5 more before the end of the month. its a pain but im starting to get some results health wise. I was going to use the galvenized sheet metal off the calv feeder to do a full belly pan but the metal is fairly thick and im not sure if its weight gain would out weigh the mpg gain i would recieve. Right now i just cant afford the sheets of coraplast to do it light weight. I think the sheet metal off the calve feeder to do the full belly pan might weigh 30 to 40 lbs. But it would need Zero reinforcement so that might be a plus. So far the only mods i have done are remove the back seat and bent the right side mirror in for less aero drag and added a Fuel Kill Switch that i use all the time now. I filled up today and broke 60 mpgs. 375.2 miles and 6.12 gallons of diesel for 61.3 mpg! One thing i did better this tank is using the fuel cut off switch and coasting. If a car got behind me while coasting i would see it as soon as it was in the rearview mirror. If i wasnt close to the bottom or end of my coast i would just turn on the hazard lights and they would just drive around me : ) The car being a 1981 I figure them seeing it going slow with hazards on would be believable : ) This tank i never got over 50 mph and at the probably 50 miles at most were on the highway. the rest was all back roads so most of the time i was between 45 and 20. Let me know what you think about using the heavy guage sheet metal for the full belly pan. if it would still be to my advange i might have to do it. I am still thinking about grill blocks..I love this car, how it drives and handles and looks. but that big open grill sure catches a BUNCH of air and i know that is huring my coasting lengths. Thanks in advance. Don |
Congrats on the 60+ mpgs!
My guess is the belly pan would be worth the extra 30-40 lbs. Curb weight of that car is probably over 2,000 lbs so 30 lbs is only a 1.5% increase in weight. Or thinking of it another way, diesel fuel weighs ~7 lbs/gal so 5 gallons of diesel fuel adds another 35 lbs. Another thing to consider is that you could make one now out of the sheet metal and then later use the sheet metal as a template for the final coroplast one. You might also want to leave portions of the sheet metal one in place for reinforcement. Plus, if you're like me, everything always goes more smooth the second time around. Consider the sheet metal pan a trial run. |
Thanks Dave.
I see your point its really not that much weight. I have a friend that has a cutting torch and he is going to come over and help me get all the sheet metal off. Its all Bolted on to the cast iron frame and all the nuts and Bolts are rusted. I think if i use this i will just do it once. at least the metal underbelly should last as long as the car. I may have under guessed the weight of the sheet metal its pretty thick but i think the Aero i get from this will more than make up for the weight, especialy at speeds or 40 mphs and above. I notice on coast downs the car really slows down fast to about 30 mpgs the it sees the wind doesnt slow it down to 20 nearly as fast. I still havent done a grill block and need to do that as well. I wanted to make sure i was getting all the results i could with just my driving first. Thanks Don |
