Old 09-05-2009, 11:21 PM   #1 (permalink)
'Stache Builder - '92 Honda Civic VX
90 day: 42.58 mpg (US)
White Dwarf - '09 Mazda 5
90 day: 28.87 mpg (US)
89 Civic owner saying "hi!"
Hello. I have an 89 Civic hatchback that is highly modded. I have rebuilt the engine with 11.9:1 compression, VTEC, port cleanup and polish, and a chipped and completely tuneable ECU. Other mods include a 5-speed transmission (from the depressing 4 speed), a diy heat extraction hood (grinder and welding, fun!), exhaust header and 2.5" exhaust and a wideband o2 controller with display on the dashboard. The engine has 1400 miles on it at this time and I am just running a rough basemap. I hope to tune it soon after I actually acquire the header. My average MPG on the basemap is 32.97 city only, including pizza delivery. I built my car mainly for max horsepower, but as we all know, efficiency is a great way to increase hp, and it also improves MPG.
I was doing reasearch on the internets one night, and stumbled across this website and found all kinds of aero mods and driving tips. So now I am hooked. My car is my daily driver, so I need good MPG, and on the weekends I can take it for a fast drive in the mountains or to the racetrack and have fun there too.
When I tune, I will shoot for lean cruise on lo-cam VTEC, and max power on hi-cam VTEC. Maybe 16-17:1 cruise. It already runs there most of the time on the basemap, and it doesn't seem to mind. I think the high compression helps the less than ideal AFR light off.
From my limited time here, I want to try a grille blockoff, air dam, LRR tires when I upgrade to 14" rims, and a partial underbelly behind the rear suspension. I'm sure I will find much more as I look around.
Old 09-06-2009, 12:02 AM   #2 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Welcome Honda bro!!!
You will like it here, there are a ton of good people and very knowledgeable.
What tuneable ECU system are you running?
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-06-2009, 12:52 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Pictures?
Welcome to ecomodder!
Old 09-06-2009, 02:55 AM   #4 (permalink)
I have a chipped p06 from a 92-95 civic with the moates.com vtec upgrade. Pics soon. Sprained my ankle trailrunning today and didn't feel like going downstairs to the computer with all my pictures on it. :/
Civic HX owner, seeking 60 MPG WTFM8 Introductions 14 03-10-2012 01:05 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
'89 Civic HF Engine Swap millenniumtree EcoModding Central 12 04-30-2010 12:32 AM
Structure - Civic IMA owner Structure Introductions 3 03-19-2009 04:17 PM
Hi, Civic Ex owner just found this board... ZachUA Introductions 12 06-03-2008 01:02 PM
