Hi~ from horsepower to MPG
Hi how is everyone. I just joined up on this site. I used to be addicted to horsepower but now im addicted to effciency.
its funny because i sell parts to make horsepower (and some effciency but, meh) on my website. I drive a 2002 4.3L / auto chevy blazer. I am soon going to be adding a MAP enhancer & PCV enhancer, and hopefully a hydrogen system with a PWM. I am already running some 02 sensor isolators that have helped with my gas mileage. I am on here to gain some knowledge about saving some gas. |
Welcome to EM!!!
I'm pretty sure the hydrogen systems are a fluke, a scam to make a couple hundred dollars quick. Unless you know how to make one yourself, then it's worth trying to test out. Go pull some sweet numbers! |
Sorry I missed this thread! Was the the airport.
Welcome to ecomodder! |
I'm a newcomer myself but...Welcome. :)
Welcome, if you post up some pictures I'm sure the members will help you make it more aerodynamic. I'm guessing your Trailblazer has a roof rack because I've never seen one without a roof rack. Well, if you don't use it I would ditch it. The best mod IMO is the driver mod, I've had great results from changing my driving habits.
already removed teh roof rack.
I did build a rearmount turbocharger for the truck long ago. went 12.5's in the 1/4 mile and did quiet well on gas when i didnt have my foot in it. burnt up a couple exhaust valves and sold the turbo kit. i also have a shift kit in the transmission to help with longevity and reduce heat/slippage. BTW- differentpointofview- i have experience with hydrogen systems, and yes they work. PWM & EFIE's / 02 isolators are the key to getting them to work as advertised ;). i will keep you guys updated. Glad to be here. |
What kind of experience do you have?
BTW, don't forget about a way to retard the ignition timing. |
Welcome to the site!
I was/am in the same boat as you, coming from horsepower to efficiency, hence the name "reformed".. although I still have my track/(*cough*street*cough*) car, so I'm not technically as reformed as I say I am. This site is great, it has really opened my eyes to all the things you can do to increase FE and there are a lot of very knowledgeable people here. |
as far as experience. the hydrogen system is basically just wiring. Which is easy. I have installed 7 full nitrous kits now so wiring is a breeze. Everything from a standalone 2 stage nitrous set-up with window switch, purge, and bottle heater to a simple wet kit with just a WOT switch. I have some experience in tuning but that is to get the most out of usually a forced induction set-up. Helped tune 2x supercharged s2000's, and my truck when it was turbocharged.
As far as retarding the timing, i will probably get a copy of EFI live to do a full street tune on my mothers truck, my truck and my brothers truck (04 5.3L Z71) |
boostanddestroy -
Welcome to EM! Looking forward to your hydrogen test results, CarloSW2 |
The only thing we are trying to do with our systems is get them powerful enough to run without a catalyst which i think is entirely possible with a PWM. We have almost cured the current draw issues as when we first installed the system it was pulling the truck from 14volts down to 8~9 volts @ idle. Now @ idle its right between 13&14volts. |
Wow, how much amperage are you putting through it?!?
Also, why are you trying to run without a catalyst? |
