Hi from portugal
Hi, i'm Diogo Silva from Portugal, i run a 2001 Hyundai coupe (tiburon) 1.6L !
I have some NONecomods in my car (like 17" wheels)...but i'm new at this! i have already buy a scangauge II but i'm having problems with it :confused: my last consumption was 7.2l/100km (32.6MPG) i'm working in undertray (front and rear prototypes done and fixed) Regards Diogo Silva |
I live in Brazil, and back here the Tiburon was never available with any engine smaller than 2.0L. How does it perform with the 1.6L?
it performs just fine! it was two 1.6 engines avaliable, the 1.6 Beta engine and the 1.6 alpha II engine (116hp/105hp) mine is the most advanced, the alpha II engine, it's more eco and have the same torque earlier (at 300rpm) it was introduced because of the EURO 3. it isn't a lot slower than the 2.0!
in other countries there was also a 1.8 displacement avaliable! |
Hi, H_RD2.
I was in Portugal briefly a couple of years ago... well, a few kilometers off the mainland coast: :) http://ecomodder.com/forum/showthrea...ing-17941.html What are your goals with your car? Have you been tracking your fuel economy all along? You're right to start with instrumentation, and focus on driving technique (it's where you'll save the most fuel). If you can't get your ScanGauge to work because of the MAF issue, you'll need to use an MPGuino, which measures fuel use directly by tapping into an injector signal. Welcome to the forum! |
Hi! i hope you liked my country :) where have you been here in portugal?
The MPGuino is an option...but... it's a lot more dificult to instal, and i have to spend extra money :( i hope they was a solution for my scangauge... |
What is the problem with the SG2, did it not work at all or was it inaccurate ?
His SG thread: http://ecomodder.com/forum/showthrea...ing-27339.html
--- I was in the Azores for 4 days. Joined a sailboat there that was going to Canada. (See the link I posted above, if you're interested) |
wow, i have never been in that part of my own country! it's beautiful!
i have news on my scangauge post, please give it a look! Arragonis, the scangaugue is just fine but it didnīt show the most important...consumption... |
where can i post my car and the mods i have made?
