Hi From Winnipeg
First post- enjoy the site and all the info.
I have a 1991 Dodge D150, 3.9l 3 speed auto. Located in Winnipeg, Manitoba, Canada. Mods so far: -antenna delete -warm air intake -1/2 grill block -plastic flushmount cover on headlights -removed rear bumper, replaced with smaller wood bumper (stock bumper hung out on the sides) -coroplast fairing off top/back of cab -higher pressure on tires -flush wheel covers (chrome "beauty rings" with coroplast siliconed on) -replaced large side mirrors with some smaller streamlined ones -rear wheel well covers -tried the alternator delete by loosening alternator and tying off belts but check engine light would come on at highway speeds (fuel injection issue?). I have gone back to alternator for now. -wiper blade delete (weather permitting) -partial box cover (back 2/3) The whole thing is flat black with the black coroplast- has a definite "Mad Max" theme going on. Planned mods: -front air dam -remove rain gutters -boat tail back (remove tailgate, fair in using coroplast) I have gone from 19 mpg to 23 mpg (based on last tank only- unfortun ately (fortunately?), I don't put on lots of miles....). Note: those are imp. gallons, not U.S. Darren |
Welcome. I have fond memories of Winnipeg, where I learned how to ride a bicycle year-round, except when powder drifted over the ice ruts. It sounds as if you are doing well with that truck. You might want to consider a belly pan instead of an air dam to maintain better clearance. I'm also quite curious about the possibility of a really lightweight aerocap made of Coroplast and framing that is hinged at one side for bed access.
Welcome to ecomodder! Pictures? :)
dizzydee -
Welcome to EM! Mad Max Ecomodder, ha ha. 21% jump in mileage es muy bien. CarloSW2 |
Pictures of Max are in the "Garage".
darren |
3 Attachment(s)
Pictures of Max
Hi dizzy. I just joined as well and nice to see a fellow winnipegger here.
Bicycle Bob, I too cycle year round here. Coldest I have done is -35 degrees C. I have an old fixed gear with studded tires- a good workout.
I have thought about fairing in the whole back end and using a wireless backup camera (the little mirrors I added are poor compared to the stock ones. For now I will stick with the current configuration. Darren |
dizzydee -
Like those pix. Now Max just needs a snake-graphic and a bed-mounted machine gun to finish its Road Warrior look : http://www.madmaxmovies.com/cars/mad...braFilming.jpg CarloSW2 |
Was the water pump hooked up ? Sirpintine belt? Discontinued alt. = no power steering p code. No water pump /maby some windmilling except 50% grill block an other p code on smog pump/air injection pre cat for finishing fuel burn aka o*2 sencer is reporting p code
what codes came up for alt deleted test try disconnecting and tape upthe wires or if possible pull the fuse For an ABAtest |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
