Higher tire pressure -> lower MPG??
Just switch from Dunlop Enasaves A/S to General RT-43H, and looks like there is 5-10% MPG penalty. There are other factors in play, such as break in, lower ambient temperatures, stations switching to winter gas mix, etc, but subjectively car does not roll as well as it was on LRR Enasaves.
The only thing I found out of order is that RT43s were overinflated to 49psi. (This is 2000lbs car). General wisdom of ecomodder says higher pressure = to better MPG, but the question I am contemplating, is there such thing as too much? RT43s are non-LRR tire, but they were designed with "Low surface abrasion technology (LSA®)" belts to reduce wear/friction. Would this also mean that at some point higher pressure will change the shape of the contact patch and increase the abrasion? |
It's likely a combination of the new tires, a less rolling resistant tire & the winter fuel blend.
Higher pressures will always result in improved rolling resistance, especially between 30-50 psi. |
I am seeing MPG improvement after dropping pressure down under 40psi |
Too many varibles, old bald smooth tires are roll easier than new tires.
Double check your brakes for drag
http://ecomodder.com/forum/attachmen...1&d=1212424018 http://ecomodder.com/forum/showthrea...tire-2721.html The tires tested were rated 44psi max sidewall. I wouldnt say "too much", but a point of diminishing returns. |
I just put some Enasaves on my car, from non-LRR tyres, and was surprised at the noticeable increases in rolling distance and mpg.
I reckon it's going from LRR to non-LRR tyres that's the sole cause of the effects you're noticing. |
Among the things that come along with excessive inflation pressure is a reduction in traction, groove wander, harsh ride, and uneven wear. I am of the opinion that tire pressure needs to be referenced to the vehicle spec pressure, not what it says on the sidewall and I think anything over 5 psi is excessive. Quote:
Marks post hits the nail on the head, my 2015 Mirage is one of the best coasting cars I have ever driven, including a 1st gen Insight on RE 92s. I can not remember a single instance where it was confirmed that increasing pressure reduces mpg. Sorry to the OP for overinflating his tires, he observed it and the gauge read 40psi, versus his requested 38. Having a pressure gauge in my glove box, I figured he could reduce the pressure any time, like myself. In the meantime he could drive the car with (what I thought based on the gauge reading) was 40 psi. he (cyclopathic) even advised me on placement of the tire in relation to the valve stem while I was changing his tires and the last two (after taking his advice) needed no weight and, as far as I know, were riding fine when we drove back to my house. We made a deal on his Ensaves, which measure exactly as new 8/32nds in all treads at 3300 miles. I have them for when mine wear out, waiting in the garage. 7300 miles on my Mirage since 5/9/15. regards mech |
This is why I also believe under inflation is the only real possible point for pressure related tire failure. The tires can be inflated to max sidewall in sub-freezing Montana and then driven across the country to 110 death Valley in the sun where I bet the pressure reading would be almost off the charts and yet still correct as being set cold. |
I see 3-4 degree swing in my car with TPMS that indicates real pressure. My Cambell Hausfield chuck indicates 28 when real pressure is 40 yesterday(stick gauge and car).
Makes me wonder if there is a correlation between the pressure rise and rolling resistance of the tires. Makes sense that there would be one.
regards mech |
Down to the manufacturer recommended 2.2 bar / 32 psi, coming from 2.8 bar / 41 psi (3 bar / 43.5 psi is excessive, as the rear gets bouncy and tail-happy) They need not have stated the fact - it was noticeable right away. The ride was sluggish, wallowing (65% profile is rather high these days), understeering, but comfy-soft . FC was up compared to what I'm used to seeing @ the speeds driven. Car manufacturers clearly use low-ish tyre pressure to hide flaws in their suspensions, at their customer's expense. My tyre wear has been lower since I started using higher pressures. Wear evened out on Hagär the Volvo. No uneven wear issues on the up! which has been using higher than recommended pressure since day 1. Quote:
I've used "excessive" pressure to correct uneven thread wear caused by using "correct" - manufacturer prescribed - pressure. |
M/C racing tires are said to grow so much that by the end of the race people would need different gear ratio. So the trick was to get it on lower side so it would be more or less ideal in the middle of the race. |
As others mentioned there are too many variables, for example starting Sept 16 they started switching to winter blend, cooler temperatures, getting gas from no-brand gas station (not that station may have been cheating, but different pumps have different shut off sensitivity). Not to say that some gas station pumps may have issues, I've put 5.3gal in 4.8gal m/c tank in the past. Bike was still running fine w/o switching to reserve, so there should have been at least .5gal. RT43 are non-LRR tire, and Enasaves are LRR, so some loss is expected. Now, what I am interested in the actual physics of rolling resistance. This is what Continental is saying about "Low surface abrasion technology": Quote:
For this very reason (sidewall heating/flexing) higher profile tires of the same make tend to be more fuel efficient. Taller sidewalls = less flex = less heating = less losses. The question becomes that if the tire was optimized for specific contact patch shape, could over-inflating and changing shape be detrimental to wear/rolling resistance? On a side note alignment is a big variable of the rolling resistance, and some tire designs seem to be more sensitive to small misalignment than others. Then again, less inflation = softer tire, which in theory should help to negate less than ideal alignment. If anyone came across any articles on tire rolling resistance, could you please post a link? thnx |
I look for tire gauges at yard sales, then match them to those I already have and throw away the ones that are way off. Older made in the USA gauges are best from my experience.
What everyone is experiencing is the "China effect", cheap tools that might be adequate for a very occasional use, nowhere near their design limits. I have tools that I bought in 1969, USA made and still working fine. The most frequent purchase at yard sales are tools. Anyone know what a "fountain brush" is without looking it up? regards mech |
cyclopathic,
Below are 2 of my webpages on RR and Fuel Economy. I'll bet most of the answers to your questions are there: Barry's Tire Tech Barry's Tire Tech |
Also have you looked at EU efficiency labeling? Could not find tire database compilation with info on tire ratings. |
Before joining ecomodder, I originally started increasing tyre pressure to cure or reduce wallowing and tram lining effects due to too low OEM pressure recommendations. |
https://www.tut.fi/ms/muo/vert/7_raw...p_image008.jpg https://www.tut.fi/ms/muo/vert/7_raw...p_image008.jpg And there is other data to support that RR is relatively the same until you hit about 60 mph, then it increases dramatically - which is probably where the video you looked at was coming from. |
I'm not sure what effect speed ratings have - or more precisely, what affect the change in construction has - but I suspect that the increased RR you get to achieve a higher speed rating is only slightly offset by the softening of the speed effect. Put another way: 1) Higher speed rating = higher RR (all other things being equal) 2) Higher speed rating reduces the effect speed has on RR, but does not eliminate the effect. |
What about centrifugal force throwing the tires out at higher speeds? You can definitely see that effect on Top Fuel dragsters. Then again 60 mph is past in a fraction of a second with those things.
On dragsters you don't have steel belts and the increased diameter is a part of the overall gearing.
regards mech |
I would think that even if diameter expansion was to blame, I would still expect it to be more linear. It's that flat before the curve that has me curious. Its like comparing it to metallurgy. That curve is the beginning of the yield curve. I know they are completely different things, I'm just trying to get an idea of a similar physical process a material goes through that has such a drastic change.
Here is more on physics: https://en.m.wikipedia.org/wiki/Rolling_resistance |
Slippage?
I think there are 2 different concepts being discussed. 1) Slippage in the direction of travel. As tires are required to generate more forward force to overcome wind resistance, the tire has to slip relative to the direction of travel to generate that force. This MIGHT have implications on RR - BUT - when RR is measured in a lab, there is no wind resistance. The only thing being measured is pure RR. That's why I think the standing wave is the reason for the increased RR. 2) Lateral slippage - as in a turn. Another way to look at this is grip. And, yes, slippage due to loss of grip is going to affect the energy loss a vehicle experiences, but I don't think that is impacting what that graph is showing. |
If an issue with wave was an issue, than there would have been a drop/increase at resonance frequency. Wheels are rotation at relatively slow speeds to have the wave make all the way around wheel. At 60MPH wheels rotate at 700-900RPM. |
