Highest MPG small cargo vans?
I live in U.S. and am curious to know what are the highest mpg small cargo vans here? The main criteria needed is the cargo height. Width and length are not as important. Right now I have a 2010 Ford Transit connect. It gets about 25mpg combined. I carry tall light weight objects in it often, like BBQ grills, Bed frames, ect. . So far Im seeing that the Japanese imported Kei vans like the Honda ACTY, are my best option. The ones that can legally be imported to U.S. But I will be driving on the freeway allot, and I see that they are dangerous on the freeway. Also Im worried about reliability of maintenance on a 90's Japan only, car. But it would be interesting to know which is best on the freeway incase I still buy one. Also is there a modern equivalent to to the kie vans, that was sold in America thats street legal? I love that they only weigh about 2000 lbs, and have small engines. Thanks allot :)
www.youtube.com/results?search_query=OCTO+february
www.thesamba.com/vw/classifieds/newads.php I don't have a picture of it, and it's gone from my life; but my 1960 Type II panel van weighed as much as a Beetle but [no glass/heavier suspension] so the the CG is as low. It had [later] 3/4 ton axles and would carry 2/3 cord of firewood. It could back up uphill on wet leaves and drive right over parking lot bump stops. With a fresh 1600 (dual Solex 40s, single extractor exhaust, Pertronix Ignitor) it got 30 MPG at 55 MPH, over the Coast Range. (Never went 55 again, it could top the Coast Range at 70) I've still got an engine I built for it, a 1776 stroker. It's the VW Mileage Motor build that would probably get 35 MPG in a Type II. |
If you can make the dimensions of a Pacifica Hybrid work those get “infinite “ mpgs for the first 20 or so miles after a charge.
I have seen folks “modify “ said vans removing the rear seats and interior, I’ve even seen the roof raised and suspension modified for handicapable transport |
Too bad GM's 4-cyl turbo diesel it's only available in their large vans and mid sized pickups. In the Chevy Colorado and GM Canyon this engine can get 30mpg. I've heard it doesn't do so bad in the full sized vans either. So maybe a Chevy Express 1500 with diesel option?
Ford also had a 5 cylinder diesel option but I don't think it gets as good of fuel mileage, although I'm not completely sure. |
Scion xB?
The Americanized 1970 Subaru 360 Sambar van gets around 50mpg highway
However it’s too speed is limited unless you do a sedan gear swap and it’s best to do some carb tuning and swap in an electronic ignition But it requires steady but simple maintenance, whole car can be tore down with under a dozen tools but old school cars had a different maintenance schedule The good things are that you don’t need to do oil or coolant changes. I would question that a non-specialized kei car would not fit your cargo That said some have tried to gas swap miles zx40’s and possibly a kei truck with a specialized box might work |
The new Connect has the 1.6 ecoboost engine, but you would need to take care about it to prevent carbon buildup. - Requires premium. But if you drive it "ecomodder" Style you could reach 33mpg and higher. - So that might be the best option... For a "big" van the Option would be a RAM Promaster Diesel about 24mpg. - Better then the Dodge Sprinter. higher Displacement (3 Lite), but this Iveco Diesel is one of the best. Powering the bigger vans and military vehicles up to 5 Tons. |
If you get em, only second hand.
