Old 12-08-2008, 10:41 AM   #1 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Coolant heater *failed*
Well, the other night I was out late, got home around 10pm. Had to be up for work at 4:45am, but I REALLY wanted a toasty car to get into, so I stayed up to midnight to install my heater (Kats 1500w aluminum tank).
I got it in and refilled the lost coolant, ran the engine for a few to burp it, topped it off. Plugged the heater in. It got hot. The hoses around it got hot. I thought "success!" and went in and got a short 4 hours of sleep.
Went back out to go to work and its DEAD. Nothing, freezing cold. Its the heater too, the circuit aint blown. I plugged a light in and its fine.
The stupid things a dud. Or is it? Anyone had similar experiences? I can ask for a return from amazon right now but if theres any hope of it working I would like it *now* lol.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 12-08-2008, 11:25 AM   #2 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
sounds cooked to me. Try another outlet to be sure.
Old 12-08-2008, 11:27 AM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Rule out the heater cord itself. I think that's more likely to fail than the heater element, assuming it was surrounded by coolant, and the coolant was flowing.
Old 12-08-2008, 11:46 AM   #4 (permalink)
bhazard's Avatar
Tried a couple outlets, the cord looks fine. Not sure how else to check other than take the heater apart, and I want to be able to send it back.
I sent for a replacement.
Best MPG - 36.8
Old 12-08-2008, 12:10 PM   #5 (permalink)
Try putting a multimeter on it to measure the resistance. I'll go do mine right now and you can compare...
OK, I'm back! Man it's cold out.
I read 16.4 ohms at the plugs/prongs of the heater cord.
Which is roughly what is should be, according to this calculator: Enter 110 volts, 16.4 ohms and hit "calculate" = 737 watts. @ 115v = 806 Watts.
Mine's a 800w nominal heater.
Ohms Law Calculator
Old 12-08-2008, 12:32 PM   #6 (permalink)
bhazard's Avatar
Took the meter to it, it read nothing except for very very brief instances, and then it read something like 191.2 ohms which calculates to like 63 watts.
Dud.
Best MPG - 36.8
glow plug based coolant heater Coyote X EcoModding Central 23 09-11-2018 06:36 AM
Mini experiments: 300w vs. 800w block heater warm up time MetroMPG EcoModding Central 73 06-15-2014 03:30 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
Why does the heater core transfer heat from the coolant, not the exhaust? extragoode General Efficiency Discussion 23 10-17-2008 10:44 AM
850 watt tank style coolant heater - installed in the Blackfly MetroMPG EcoModding Central 4 11-28-2007 02:10 PM
