HMMMM hydraulic hybrid f150
Non-electric Ford F-150 hydraulic hybrid could get 40 mpg
Lets see where this one goes, versus the 60 MPG claim for the "Tonka" version a few years back. I am skeptical since the EPA design uses a pump running at prop shaft speed where higher speed efficiency drops off fairly dramatically. In wheel drives resolve that issue. regards Mech |
i've been thinking about building a hybrid with Freon instead of hydraulic fluid. The freon gives you a lot more push, and I would use waste heat from exhaust/radiator to heat the freon for higher pressures.
The idea is to keep the size of the tanks small by using liquid freon as the storage medium, but the low pressure of heated freon (500 psi or so) would require a larger motor/pump to work. |
Back in the late 70's there was a Granada hydraulic hybrid. It got 38 city mpg.
Weighed 1000 lb's than standard one. |
Been done before?
Yeah, I read an article in a 70's Popular Mechanics magazine about a similar system in a Cordoba or something, and it worked quite well. It used a hydraulic pump/motor on the driveshaft and a giant accumulator.
You can currently buy a version of this system in one Peterbilt model: ..:: Peterbilt Motors Company ::.. |
Been done. UPS has a number of hydraulic hybrid delivery trucks, and there are HH garbage trucks available: Autocar launches E3 hydraulic hybrid garbage truck
The problem with a pickup version is that the big win comes when you have a duty cycle that involves a lot of stop & go. |
What I'm referring to is the kind of modification that fits the Ecomodder model: small, simple, within the limitations of the "average" garage/shadetree tinkerer. Those Autocar, etc. are trucks with plenty of space and capacity for large, heavy components. To do this kind of modification on a 60's model Fiat 500 (smaller than a Vee-dub) was an achievement...and without the kind of funding companies like those have, both private and taxpayer sourced. In addition, neither Carman nor Ernie Parker (who is still with us today) had access to the engineers, industrial equipment and facilities that Eton, Ford, Autocar, Parker, et al have. Sure like to see a successful duplication of the little guy efforts, like the EV build we see by the multiple dozens. By it's not having been done for quite a long time, it's not easy. It requires a great deal of focus on purpose and commitment, as well as time, though probably about the same amount of money as an EV conversion. |
