"Economy Driving" by Doug Roe
Major points taken from a 1974 book called Economy Driving by Doug Roe.
1.) Cornering Speed vs. Tire Wear Driving through a turn at high speed to maintain momentum is generally not a good idea. Second to gas, tires are often the most expensive consumable a car owner faces (oil arguably being neck and neck). Tires wear most rapidly during turns. This can be seen in track racing, where tires often only last 100 miles due to high cornering speeds. Generally, for every 10% increase in cornering speed, tire wear increases 50%. 2.) How to deal with stop signs. I'm not sure of the reason behind Roe's method, but I suspect it is to aid in timing. In any case, this method will depend on your car's gliding distance. Roe chose a 1/4 mile for the example. At 1/2 mile from a red light, ease off the throttle so 2-5mph are bled off by the 1/4 mile mark. At the 1/4 mile mark, completely let off the gas. 3.) How to Pass on a Two-Lane Road Maintain a healthy following distance (~5-6 seconds) behind the car being passed. Visual Following Distance http://www.brittany-ferries.co.uk/me...car_road_2.jpg Occasionally, ride on the leftmost portion of the lane to observe opposing traffic. When an opening appears, accelerate swiftly to passing speed while staying in the same lane. Right before the following distance is gone, swerve into the opposing lane and overtake the car. The idea is to minimize exposure in the opposing lane while maintaining momentum. Supposedly, this is a trick heavily used by truckers. An interesting "what if" was posed: What if an opposing car should appear during the overtake maneuver? Speed up (leadfoot) or use the brakes? Roe suggested speeding up and taking the fuel economy hit of wide open throttle simply because that car was being overtaken for a reason. By flooring it, you save youself the potential of being stuck behind the guy during a crucial maneuver (e.g. climbing a hill). If you are in front, you get to set your own pace. 4.) How to Climb a Hill This was before the days of FE instrumentation, so this may be most applicable to "blind" drivers. Also, for legal reasons, Roe doesn't suggest engine off cruising even though he mentions it was (illegaly) used during the national competitions Long, shallow hills (1-5 miles) are best dealt with by maintaining cruising speed. If you cannot accelerate quickly on the following long, shallow, downhill grade, you are better suited to stick it out. The idea is that if you want to maintain a trip speed of 40mph, you have two options. Option 1 is to deccelerate (let's say, to 20mph) on the uphill, forcing you to accelerate to 60mph on the downhill. Option 2 is to deccelerate to 38mph on the uphill and let gravity pull you down at 42mph. Option 1 will require you to use gas to accelerate up to speed while Option 2 uses a pure gravity assist. Stopped at the Bottom of a Hill is best dealt with by accelerating swiftly (just under enrichment) to gain as much speed as possible before the hill really steepens. Accelerating and climbing are two evils, so it is best to minimize the first before the second begins in earnest. Tricks, Suggestions, Information
LostCause -
The tire wear issue is interesting. I will watch for wear (around the edges I presume). I don't corner too hard, but I am faster than I used to be. Another term for this could be Life Cycle Hypermiling. Sooooo, to save bytes :D , we could have acronyms of HH and/or LCH ( ... or HHM and/or LCHM). CarloSW2 |
what is this book called?
I am excited for the next update! |
The book is called Economy Driving, by Doug Roe. I think it was published in 1974. Unfortunately, the book is aimed at the layman, so most of the information present would be pretty obvious to everyone here. It still served as a cool history lesson and it was neat to actually find a book on the subject. I didn't know they existed. :)
Anyway, there were some neat safety/hypermiling/money-saving driving tips, so I've updated the first post. - LostCause |
Thanks. So in 30 years I take it people will be reading Economy Driving by MetroMPG...:p
The 100 tips is great, especially as you went beyond "hypermiling." It's also nice to see the site hasn't run out of creative energy! :) It would be cool if there is an illustrator on this forum who could draw up some pictures. Creating an illustrated DMV-esque booklet would probably be the ultimate. Print out a couple million and give them to the smut peddlers that line places like Las Vegas and the world would be converted. :p - LostCause |
My local auto salvage yard charges $12 a tire and there are almost always nearly new tires in there. Thankfully, I drive a very common car.
huh, my tires are the second set I'm pretty sure, and they have about 90k on them. I corner so hard I bottom out the suspension, and no noticeable wear has been seen. These aren't very sticky tires though.. very crappy in fact. Uniroyal tires. Last a long time though. I do need to rotate them.
