EcoModder.com
-   The Unicorn Corral (https://ecomodder.com/forum/unicorn-corral.html)
-   -   Home made all "free" energy hybrid (https://ecomodder.com/forum/showthread.php/home-made-all-free-energy-hybrid-26273.html)
jarmstrong1010 06-29-2013 01:55 AM
I am new to this and wanted to know if it is possible to make a electric car with one of these "free" energy motors in the trunk to power the motor under the hood.
This is my thinking , convert old car to electric, but instead of having to plug it in, just install something like a magnet motor or one of the new "create electricity from the ether" machines that generates electricity in the trunk and drive till the tires fall off, or I get old and die.
And if so, where do I find the plans.
As I currently may not know enough about this subject, I ask if it is possible as I do not see why not. Or, maybe nobody thought of doing it yet, it seems like the logical thing to do, combine the electric motor with the "free", "unconventional" "new age" electric generating device and drive, drive, drive.
Or maybe even just install one of these new energy making machines in the trunk of a modern factory made electric car?
So PLEASE, tell me how to make it work, I think I can, I think I can. Thank You.
Joe
Frank Lee 06-29-2013 02:04 AM
No doubt, it is the logical thing to do. Get going on it and post pics please. :thumbup:
AntiochOG 06-29-2013 03:54 AM
Strong first post
jakobnev 06-29-2013 04:31 AM
I think i can, I think I can.
Just follow the yellow brick road. And when you get to the wizard, ask for one.
NachtRitter 06-29-2013 05:28 AM
You can get a ride from the little engine that could...
niky 06-29-2013 11:18 AM
The magnet goes on the other end of the car. Not in the trunk!
Then find a nice, big truck to latch onto next time you're on the highway. Once you're hooked, engine off... ∞ miles per gallon.
some_other_dave 06-29-2013 03:44 PM
But where's the ad? These posts usually have an ad for the "free" energy engine!
-soD
Ryland 06-29-2013 07:14 PM
Then you get good regen brakes on your electric car so you can charge the battery pack up by ridding the brakes as you drive then plug in and sell power back when you get home, you'll make it rich! you could be retired in just a few weeks.
freebeard 08-06-2013 02:32 AM
That comedy gold right there. :) If you think the reception to your [brave] first post is mocking, you should go post on Volksrodder.com. They are so hostile to newcomers there that I refuse to register. They won't let you lurk.
You deserver an answer.
tesla free energy car - Google Search
Plausible? Possible? Actual? Rumor has it...
markweatherill 08-06-2013 11:56 AM
I don't have the skills to build one of those free energy motors, besides which I am sceptical that they even work.
So instead, I plan to run an inverter off my electric car's 12V battery and use that to charge the main battery while I drive.
jakobnev 08-06-2013 04:09 PM
The opposing view would be that it must be the free market that provides these things.
cRiPpLe_rOoStEr 08-06-2013 06:49 PM
I don't trust any of those "miracle" free-energy devices. Well, there was a Greek philosophist who used to say that nothing could be created, altough everything is transformed (it also applies to energy). But after watching a handheld Sterling motor which converted body heat into motion energy, who never lurked about a similar device to be matched to an alternator? :D
Originally Posted by Old Tele man (Post 383802)
...must be something from our Gobberment because they're the only entity that makes "free" stuff available to undeserving people.
LMAO
Viturro 08-06-2013 07:23 PM
i think i saw one of the ''engines'' that you say, but, just on the internet, and even if it were real you couldn't aproach that ''energy'' ''generated'' in a electric or mechanical way. cos i saw that they need lot of speed to ''start'' in a mechanical way transfered by a chain to rear wheels (the most less braking way) then you will need a clucht that could be centrifugal/manual... then make that engine spin (¿how?) to high revolutions with some kind of heavy flywheel (to be able to spin the wheel,becouse it have no torque) and touch the clutch... but now every little spin of it will consume a lot of friction, that gets worse whit the chain, worse with the clutch, and worse with the flywheel (and the vehicle wheight)...but all that is simple to solve if your engine really works good : D
cRiPpLe_rOoStEr 08-06-2013 07:41 PM
Well, eventually a Sterling motor to drive a cooling fan with thermal engine recovered from the radiator, or an alternator with exhaust heat, would be the most realistic way to recover some "free" energy.
Viturro 08-06-2013 09:09 PM
yes ''free'', no free XD ... 30% of the heat of the engines goes to the radiator, and other 30% skips from the exhaust... with the a/c, alternator, water pump, you just keep with a max of 22% of the engine heat power, of those 22% 15 is consumed by the gearbox, 4% the rest of trans and something of 10-15% from wheels, then you have something of 17% of the engine converted to movement and at 60mph you just have 4% more in your nice box of 60 hp XD...
Ryland 08-06-2013 10:20 PM
If you could make a free energy device, why would you bother putting it in a car? you wouldn't need to go any where at that point, everyone would come to you to bask in your awesomeness!
But really, if you want plans for a free energy device, just send me $100 and I'll tell you how to build the best one out there.
UFO 08-07-2013 03:47 PM
Check's in the mail dude!
AlaricD 08-15-2013 04:09 PM
Amateurs. I just use a solar cell to power the light bulb that shines on it.
Don't be jealous.
Frank Lee 08-15-2013 05:57 PM
Could be any business; they make free stuff available to their execs. The more highly compensated the exec, the less of their own money they actually have to shell out for anything.
vacationtime247 08-16-2013 03:15 PM
Working on an electric car that runs on free energy. Similar to how bumper cars work. Hook an extension cable cord out the top of the engine bay and run off the power lines. OK, it's not 'free' energy. But it'll be free for me!
VT247
Aero 08-16-2013 09:41 PM
Tesla would roll over in his grave...
nemesis 06-15-2014 03:21 AM
Where do these people coming from with these get something for nothing ideas? Did they ever heard of physics? I should build an app for these people since I know that they own a latest smart phone on the market lol. Here's how it would work. You click a button and tell the phone about your idea of free energy motor.................and when you're done the app will tell you if it's a million dollar idea.................It should be pretty simple app, it would only have to say one thing................" if you think this is a great idea..........you should really consider about never having kids"
user removed 06-15-2014 08:09 AM
I like the idea of maximizing the benefit for the energy I consume. I know better than to think it might be free, unless you look to solar, including evaporation. Even then you do not have an unlimited resource, just one we hope will "OUTLIVE" our civilization!!!! After all, the best place for a fusion reactor is a long way from here.
regards
Mech
inanitydefined 06-15-2014 10:59 AM
Put a wind turbine on the roof
freebeard 06-16-2014 01:08 AM
There's also Moon power. Solar[/wind/wave] power is variable due to the complex nature of flares, the solar wind and cornal mass ejections. Moon power, produced by an inert body and on the other hand, you can set you clock by.
http://www.adn.com/2014/06/15/351875...ml?sp=/99/328/
inanitydefined -- If you do use this one:
http://www.tuvie.com/wp-content/uploads/flow1.jpg
http://www.tuvie.com/flow-wind-solar-energy-system/
Close it when you drive, and open it when you're parked, drive one day a week. It's even a solar panel.
Cobb 06-17-2014 05:35 PM
NO, NO, *#^$iING, NO!!!!! :mad: You draw free energy from a vacuum, not create electricity from ether. :rolleyes: Did you even read Maxwells theorems?
t vago 06-17-2014 05:43 PM
http://fullerbrushvacuums.com/media/...-pw4_angle.jpg
How do you draw free energy from one of these? I've had an upright vacuum for more than 15 years now, and still I can't get any free energy from it.
Cobb 06-17-2014 06:13 PM
You ever try reversing the plug? :rolleyes:
t vago 06-17-2014 06:32 PM
http://www.fugly.com/media/IMAGES/Ra...de-by-zero.jpg
Cobb 06-17-2014 09:11 PM
Now youve done it.:eek:
Originally Posted by t vago (Post 430276)
divide-by-zero
jamesqf 06-18-2014 12:59 PM
The problem is that a) you really don't have a good enough vacuum (they really should be called 'sucker cleaners', but that wouldn't sell many); b) you aren't doing quantum: Vacuum energy - Wikipedia, the free encyclopedia
inanitydefined 06-18-2014 01:43 PM
Ocean power, the other renewable, is on its way | Opinion | ADN.com
If you close it when you drive you can't get the "free energy" of the wind spinning the turbine :rolleyes:
Though how fast does that deploy? I wonder if it could be used as an aero brake, or when EOCing...
freebeard 06-18-2014 02:00 PM
Thankfully we've moved beyond the old, lame joke. :thumbup:
You can know everything I do by following the link. I suspect it's a college student's project. You can do a lot with 3D rendering. But I like the overlapping, highly optimized blades. Imagine a pet turtle with that strapped on as a rocket-powered back-pack. "Gamera is really neat..."
And I was thinking charge while parked, consume when driving. Isn't that what full electric cars do? With a light wind-week you could just take a pass past the gas station to taunt them; but with a monster supercapacitor on a trailer in the driveway, after a tornado you could go on vacation.
_______
You have to start with a washing machine.
fisher paykel washing machine motor wind generator - Google Search
bestclimb 06-18-2014 02:13 PM
I had this idea in middle school. Put electrical parts of a generator in place of the gas engine in a front wheel drive car. then put the rear axle from a rwd car in and an electric motor bolted to the drive shaft coupling. wire them together with a variable resister connected to the accelerator
Thought it was a great idea until I realized that I had no way of getting going. But if I started at the top of a hill then I could roll down to make the generator turn and thereby power the electric motor.
but
Then you get to the bottom of the hill. SO here is the genius part, downshift. put the transaxle in 1st or 2nd. muhahaha generator is turning faster than the electric motor. I would be able to drive for ever.
I'd just have to remember to park at the top of a hill.
Then I realized stop signs exist.
Cobb 06-18-2014 07:06 PM
Scalar field theory - Wikipedia, the free encyclopedia
" in contrast to a vector or tensor field. The quanta of the quantized scalar field are spin-zero particles"
