Honda Accord configuration
I'm pretty happy with the numbers I have so far. Some further tweaking may be needed, but I thought I'd get this up there at least for posterity.
This is on a 93 EX coupe, I've made modifications but they shouldn't make much of a difference. VSS: 8208 ms/gal: 196692124 tank: 17.1 gal or 17100 Use these numbers as a starting point for 90-93 accords, all trims. They are all versions of the f22a engine, they all use the same injector and the same vss. |
