Honda Civic Hybrid OBD II DTC B0302?
Anybody have any idea what this DTC is? I assume it's a Body code, but the generic codes don't go that low. I think it may be a Honda specific code.
What model year Civic hybrid?
I'm not having any luck with a B0xxx code, but P0302 is a misfire in cylinder two. |
DTC is when you have deactivated DSC. DTC is only the electronic limited slip differential and I believe if you get too far out 'there' it will try to save you if you are not too far gone.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
