Honda HF 8v engine and trans w/ fresh rebuild
I have for sale a D15B6 8v engine w/ transmission and shift linkage for sale.
Engine has a fresh rebuild and has not been started yet. It has new King main and rod bearings. All new gaskets for engine reassembly, with new water pump and timing belt. Pistons have new rings, and all tolerances are in proper spec. The block was cleaned and painted as you can see in the pictures. Valve cover has been cleaned and paint has been sanded down for a smooth finish. Comes with intake manifold, exhaust manifold, and alternator. Transmission is a L3 cable and gear ratios are as follows: 1st: 3.250 2nd: 1.650 3rd: 1.033 4th: 0.823 5th: 0.694 Super long trans for the best economy. This is the engine/trans setup that can get 55mpg right off the bat. Also comes with shift linkage and shifter. Located in WI Pictures soon! |
Pics
9 Attachment(s)
Here are some pics!
8v motors are cx not hf or vx unless this was a pre 88 motor. Looks nice.
HF are 8 valve.
Did I miss the price? Six you're so far away, I need a trans and have wanted this setup forever, you can never find an HF that's stock.
Do you know if it was originally a Cali model or a 49 state model? The cali trans had the 3.250 final drive and the 49 state had the 2.95 final drive.
HF motor/trans
Looking for $800 obo. I don't know which final drive it has in it. It's possible for me to ship freight to whatever location for an additional fee.
Original plans were to turbo it with a lean tune for about 60+ mpg. Plans have changed though and I can;t use the trans for the new build so away she must go. |
Update
I will include shipping in the price. |
Bump
still up for grabs?
i have a nice glider i was looking to put this drivetrain into. |
