Honda OBD2 (OBDII) trouble codes
On Honda Tech I found this list of diagnostic trouble codes and thought I would share it. I got the CEL and P0108 today. I'm going to reset and see if it re-occurs, because I think it could be a fluke, given that I have a injector kill switch that cuts the ground to the PGM-FI. Could be the MAP sensor needs replacing too.
james |
it's good for me, thank you for your the list of diagnostic trouble codes
