Honda to rely on GM powertrains
Honda will be purchasing EV batteries and motors from GM for the next few years at least.
Any thoughts? Seems like a pretty big deal and a reversal of the status quo from several decades ago. "Acura said not only would GM help to develop the two SUVs, but it will also be responsible for producing them." https://www.roadandtrack.com/news/a3...ars-for-honda/ |
Without reading the article, I can't say I'm terribly surprised. After owning two GM EV/hybrids, I can honestly that they're good vehicles. While the volt and yukon hybrid are very different in size and technology, they're good at what they are.
Honda crapped the bed on hybrid batteries more than once, not surprising since they let themselves fall behind
They may be in it for the battery technology.
Makes sense to rely on a bigger player to make compliance cars. Ultium is promising, and GM has solid electrics.
Honda will go in house when the timing is right. |
Honda and GM used to exchange engines, with GM supplying its Isuzu-designed Circle-L engine for Honda to use in the Euro-spec Civic and receiving a Honda V6 gasser meant to be fitted to the early Saturn Vue.
Since it appears that battery supply is an issue for almost everyone, I would guess that this is a way to access GM's battery supply chain. I'd bet that Honda is still doing their own thing in preparation for 2028 and beyond ... or whenever they can secure access to battery supply ... |
It makes sense in the near term. Honda doesn't need EVs to meet global regulations. They have been clear that they see hybrids and plug-in hybrids to be the best short to medium term solution to meet global regulations.
Honda is working on a new dedicated electric car platform but it won't reach production until the second half of the decade. Honda is also a smaller player than most people think. Yes, they sell 5 million vehicle a year but their largest competitors sell twice that many. They need to pick their R&D spending wisely and can't afford to spend a lot of money on EVs before they are mainstream. |
Bosch, Continental, and Valeo all make 48V systems for OEMs. |
Check the video on this link: https://www.valeo.com/en/offering-a-...rtrain-system/ |
1 Hp is about 750W, or around 15 amps at 48V (15 amps works at 50V). 10 HP - 150A 100 HP - 1500A (!!) The transistors used do have some losses. Power relates to the square of the current. So your cooling system has to get rid of all that heat. Golf cart style vehicles top out at 500 - 1000 amps for a few seconds, and run in the 100 - 200 amp range when cruising. I don't think that a freeway vehicle can get enough current out of 48V for long enough to matter. The VW beetle used to get up to 55 mph with .. was it 30 HP? Not many vehicles around that light or with decent aero ... |
