EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   hooking up an egr... (https://ecomodder.com/forum/showthread.php/hooking-up-egr-13188.html)
sc2dave 05-09-2010 02:25 PM
86 toyota 22r.I've stripped off all the smog stuff except the egr valve.What needs to also be connected in order for it to work?
bgd73 05-10-2010 08:03 PM
EGR valves...
cali plays with that stuff, my locale goes insane over it.
it got so bad I made the spot it was in a heatsink until the radioactive ticks finally decide to leve my precious brain alone, and bottom of windshield, and exhaust sytem, valves, headgaskets, and fuel mileage.. but its up to you to get it going. There is not one reason for itys existence. there is pros around here that taught me how to get it out of the sytem. The 22r is a classic for toyota..you may be able to argue some reason.
If california has not deciphered how bad that 1970s-80s spree was and allowing for removal, you may be out of a good toyota. :rolleyes:
sc2dave 05-10-2010 09:52 PM
Originally Posted by bgd73 (Post 174036)
egr valves...
Cali plays with that stuff, my locale goes insane over it.
It got so bad i made the spot it was in a heatsink until the radioactive ticks finally decide to leve my precious brain alone, and bottom of windshield, and exhaust sytem, valves, headgaskets, and fuel mileage.. But its up to you to get it going. There is not one reason for itys existence. There is pros around here that taught me how to get it out of the sytem. The 22r is a classic for toyota..you may be able to argue some reason.
how about making some sense???
Daox 05-11-2010 08:01 AM
Is there a vacuum diagram under the hood? There should be a vacuum line and vsv going to it to control when it opens.
sc2dave 05-12-2010 12:26 AM
I've found this :22R, 22RE, 22RTE Vacuum Diagrams - Pirate4x4.Com Bulletin Board Do i really need a vacuum modulator?
