hot fuel vs. cold air
ive been thinking about this. you can have a hot air intake to heat the fuel up so the gas burns better or cold air because its more dense then hot air.
but the i found out for every 25 dreases you heat the fuel up is one mpg and for cold air its every 11 dreases colder its one mpg if i remember right so my q is this has anyone tested this?::D |
*) This is true only for gassers. Diesels like cold intakes for both power and FE. |
I have found that heating gasoline to 180 deg. F yields about a 10% return improvement in fuel economy. Detonation threshold seems about the same for a given octane value. Greater tendency to vapor lock during hot restart. Most OBII ecu s have the ability to recognize this condition and will keep injectors closed until engine restarts. May take 2 or 3 tries but it will fire up. Heating intake air also improves fuel economy but I have found a greater tendency to go into detonation especially when ambient temps. go above 60 deg F. If you run a dedicated water or water/methanol system you can effectively supress detonation with even the lowest octane fuel.
Diesel or gas?
10% cool :D is there any way that can hurt my truck??? if not sounds like im going to be heating some gas do you use the coolant? to heat it |
probably not
all systems run most of the time at an
Air to Fuel ratio of 14.64 to 1 1 part fuel 14.64 parts air by weight so 1 part of fuel will have much less influence on the temperature of the complete mass entering the combustion chamber than the 14.64 parts of air and on systems that have a return line that extra unused very heated fuel goes back to the fuel tank , heating the fuel in the tank which causes heavy duty evaporation and pressure build up in the fuel tank much of that pressure and HC can be vented to atmosphere because most systems are not designed to handle that scenario fuel vented to atmosphere does not increase FE as it is wasted 10% improvement .... not very likely Quote:
your right!!!!!!!!! but what if we bypass the return line? |
I would listen to mwebb - heating fuel will probably have little effect on anything. |
PS--mine's turbocharged--would that make a difference in optimum air temp for FE? |
This is what Honda does in later models . the pump, regulator are all one unit with sender in it . This would or could have a tendency to vapor lock more than with regulator at rail . |
new er cars control fuel pressure other ways
new er cars have fuel pressure sensors and they duty cycle current to the fuel pump to regulate fuel pressure using a feedback system with the fuel pressure sensor.... but why not just heat up the air ? tap into the radiator shroud , the air will be regulated at whatever coolant temperature is ... low tech ... easy .... and you are heating up 14 times more mass of combustion charge without any drama or safety issues . will there be any benefits ? a definate maybe or , i dunno . but if not the modification will be easy to un modify . there are no significant "suction throttling losses" on diesels as they do not have , throttles . unless they have EGR and are computer controlled then there is a throttle of sorts that is used to lower pressure in the intake and some have a throttle in the exhaust to increase exhaust pressure at the same time so that EGR will flow from hi pressure to low pressure .. and they all have EGR |
I would pull air from the exhaust manifold heat shield for a HAI. Use tin foil to channel as much air around hot things as possible. Much hotter and steadier temps than the radiator shroud. |
800f is too hot
i would swag that
exhaust manifold temps are too high , can be upwards of 800f under load , OEM systems that used to draw hot air from the exhausts had simple bimetalic spring loaded flaps to regulate temperatures to the intake UN regulated heat from the exhaust manifold is probably not a good idea hot air from the radiator shroud will never exceed about 250f to 300f and while it may vary , it will be pretty stable at cruise . |
Is there an optimal IAT for best BSFC?
Q what is the best mod you have ever done? |
(1 kJ/(kg K)) * (14.7 parts air) * (30 C + 273.15 C) + (2 kJ/(kg K)) * (1 part gasoline) * (90 C + 273.15 C) = (1 kJ/(kg K)) * (14.7 parts air) * (303.15 K) + (2 kJ/(kg K)) * (1 part gasoline) * (363.15 K) = 4456.305 kJ/kg + 726.3 kJ/kg = 5182.605 kJ/kg Now, to find the final temperature of this mixture: 5182.605 kJ/kg / (1 kJ/(kg K)) * (14.7 parts air) + (2 kJ/(kg K)) * (1 part gasoline)) = 5182.605 kJ/kg / (16.7 kJ/(kg K)) = 310.3 K or 37.2 C (98.9 F). This is a 12.9 F difference between the initial and final temperatures. Given that my documented HAI gain of around 5% is done with an intake air difference of about 45 F, I would have to agree that 10% improvement with fuel heating seems rather unlikely. |
a EV cool how may deep cycle battery's are you going to use?:thumbup: |
Probably 12. Here's the thread:
http://ecomodder.com/forum/showthrea...gun-19957.html |
I would also wonder how heating fuel to 200F or so would affect long term reliability of injectors and even fuel pump as the fuel is used as a coolant . |
