Old 11-04-2011, 02:12 PM   #1 (permalink)
EcoModding spendthrift
WindedWarrior - '12 Ford Focus SE
90 day: 33.46 mpg (US)
Towing an extra battery pack for plug ins extended range
So, Electric vehicles are basically all torque. I'm wondering instead of getting range anxiety why not just have a towable extended range battery pack?
Those of you who are electrical engineers might be able to answer the question of a Tank 2 switchable system like the old trucks... what system surges should be worried about? Can a parallel system teaming the two battery packs together be a useful system? What suggestions do you have for such a system.
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
Old 11-04-2011, 02:44 PM   #2 (permalink)
Its been talked about many times. Some people with EVs have done it. Its not a bad idea.
Old 11-04-2011, 03:53 PM   #3 (permalink)
Perhaps when people start replacing battery packs they can use the old one for this type of backup range extender.
~ Boston George
Old 11-05-2011, 12:19 AM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I've thought about building one with my spare pack from my EV but range anxiety is something you get before you buy the car, not after you've owned it, unless you can't do math and bought a vehicle that doesn't fit your needs.
If you have two packs you want to use them both at the same time because you will get more range out of them as you discharge them both slower.
If you look at Steve Hawkins' RXT-B (range extending trailer) you will see a battery trailer that is adding about 55 miles of range, the guy says he's increased his range from 80 to 135 miles by adding more or less an identical pack to what the vehicle that is towing it is using.
The Following User Says Thank You to Ryland For This Useful Post:
dcb (11-05-2011)
