How about a 2000V VFD 0.5HP motator?
spectrum.ieee.org: Electrostatic Motors Reach the Macro Scale
Think the gaps are too small for 2Kv, even in a vacuum, it should just arc unless there's thick HV insulation on those plates.
The actual article:
Well, sorry..... nothing in the picture or article demonstrated a fluid flow path unless they inject it through the bearing races, and I don't see a seal on the encoder end or an output port. Sealed low hp, low duty cycle could be practical, but I want to see a viable 25 hp version dealing with cooling the "special fluid"
Btw my turkey rotisserie is 1/8 hp |
Interesting concern about the shear forces. I was going on using some sort of steel, now I wonder how abrasive the dielectric could possibly be. Case hardened steel is somewhat magnetic.
Fractional hp for robot joints? Much rpm and gear reductions , then. |
Quoting the article again:
Vfd would have more to do with rpm. Hmmm wires instead of discs. Hmmm.
IIRC VFD enables forward/reverse in software. Something like a stepper or selsyn motor.
What it's about is controlling crankshaft rotation. |
