EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   how to check aeromod efficency easily and quickly and cheaply (https://ecomodder.com/forum/showthread.php/how-check-aeromod-efficency-easily-quickly-cheaply-19993.html)
radioranger 01-05-2012 12:58 PM
Been thinking about aeromodding for a while, about twenty years ago I had a ford van with the usual short hood nose , I had some access to some blocks of styrofoam so I made a extended nose for it , directing the air around to the side and a panel extending down to make the grille area a bit smaller, anyway how to check it, well with a friend I went out on the highway and crusied a steady 45 , after stabilizing the speed and reviewing the traffic , I would floor it when my co pilot said go, I would drive and watch the speedo and as soon as we hit 65 I would shout stop, setting the time for 45 to 65 MPH , we did this for about ten miles each way with and without the new nose pieces, averaged around 12 percent better times with the new nose, and a lot more downforce on the front of the truck , think of how they made the UPS trucks look and you have it, anyway that is a way I think to check without any special equipment or danger,
radioranger 01-05-2012 01:03 PM
I forgot to mention we used a stopwatch ,
UFO 01-05-2012 01:17 PM
A reverse coast down. Hopefully your engine power is the same for each test, just one more variable to control.
radioranger 01-14-2012 08:35 PM
checking aeromods
That would work too, just not as dramatic. !!anybody out there try to put a small rowboat on the back of their pickup as a cheap aero tail , I tried it by accident a long time ago , bringing my 7 ft rowboat to the shore on the back of my ranger , upside down and nose of the boat hanging over the back of the tailgate, It seemed to really help but sold the boat a while back so cant confirm, could be a cheap eco mod and also you can always go fishing!
