Old 01-15-2012, 11:26 PM   #1 (permalink)
The Burner - '93 Volkswagen Golf TD GL
90 day: 42.13 mpg (US)
MPGuino my 1993 VW Turbo Diesel?
Can this work with my 1993 VW Golf Turbo Diesel? It has a belt driven mechanical fuel pump, throttle, and fuel injection system so there is no electrical involved in the fuel injectors as far as I know...
Old 01-16-2012, 01:25 PM   #2 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
You will need something to translate fuel use into a signal for the system to pick up. There's been talk of using two devices that measure flow, but those are kind of inaccurate from what I've heard I think using a TPS to measure throttle position would be more accurate, but it would also be harder because I don't think throttle position versus fuel injected is linear, so someone would have to include some programming that could guesstimate what kind of function it followed based on the TPS data and fillups, kinda like calibration with a SG.
Old 01-16-2012, 02:28 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
yah that is about it. With just throttle position and rpm I think it is doable, but one needs to map out fuel flow at various permutations of those parameters to accurately track fuel consumption, and it can change if you change the smoke screw setting (and as the pump wears).
So if you can hook the pumps/injectors up on the bench and point the injector(s) into a beaker, add tps and rpm signal, and take maybe 100 readings (10 throttle positions at 10 rpms) and chart that out to fuel flow, that would be one way. Then build the map into the chip and read the same tps and pump rpm and interpolate the fuel flow and etc.
Another approach discussed is sensing the fuel pulse length (piezo?), and injected quantity is then a function of RPM, pretty much.
Old 01-16-2012, 08:34 PM   #4 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
This interests me, also, as I'll be exchanging my 1.8 gas to a 1.6 diesel and already have an MPGuino. Is there a pressure switch that could be put inline with the injector lines?
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 01-21-2012, 09:41 AM   #5 (permalink)
I was thinking about my history working in industry. It's fairly simple if you want to determine a flow to just call the instrumentation department and get them to install a flow meter on a (fuel) line, then use the output against other variables to calculate whatever you want with it. It would be nice if there were a flow meter available for our cars, then you could just grab the output and plug into the mpguino, if that's possible? I know next to nothing about mpguino. But I was looking at the injectors the other day and each injector seems to have a return line coming out of it, meaning some of the flow going into the injectors may get returned to the fuel pump. So in that case you would need to have two flow meters, one for the flow to the injectors, and one for the flow out, subtract the signals from each other and use that as your fuel flow. Easy right. But I am brand new to diesels so maybe one line is for idling and the other is for acceleration? Who knows? Who can point us to this theoretical flow meter?
All of this manual calibration sounds like a whole lot of work to me. The ease of just plug and go of the scan gauge to the 96+ vehicles is more my style.
To me it seems easier to make a fuel cell like they use for fuel efficiency testing on myth busters. Weigh the cell before you leave, then weigh it after. Calculate your MPG. Test a route driven with different driving styles, compare results. There are only a few situations that I am curious about and this would seam like a good way of testing them. Once you figure out how to drive with the least fuel use on each route, drive accordingly in the future knowing that you are at maximum efficiency.
Old 01-21-2012, 11:32 AM   #6 (permalink)
is there a flow meter that will work at 150 bar and beyond? I have seen some piezoelectric sensors that will clamp on a diesel fuel line that senses the fuel pulse to determine RPM, but never have seen an inline sensor after a diesel pump with fuel flowing thru it. However, that doesn't mean it does not exist
Old 01-21-2012, 09:15 PM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
yah, the clamp on piezo sounds like it can give you both rpm and pulse length and be easy to install, but it is a bit of signal processing to code or hardwire to make sense of it, and newer tdi use lots of little pulses which really ramp up the resolution demands on the cpu.
Older mechanical pump diesels certainly could use such a system, but if there is a computer adjusting the line pressure or making really tiny pulses it can get tricky.
Old 01-23-2012, 11:37 PM   #8 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no --- use a used MAF sensor
reading further down in this thread some have suggested measuring flow in the hi pressure injector lines
do not do that
you can measure flow in the supply line then subtract
measured flow in the return line
both are low pressure
which is not very practical but there will be none of the problems that will arise from an attempt to measure high pressure pulsed flow
air fuel ratio is not controlled so measuring incoming air will not help , but measuring incoming air flow can give you a relative value that you can minimize to maximize FE
you can use a MAF sensor that can be plumbed into your intake all you need is a 5 volt supply and a ground on a hitachi type MAF which were / are readily available
and you can put a scope on the MAF output and measure flow per cylinder
relative flow
all must be the same exact signature , you can easily pick off dirty valves or low compression or contributing cylinders
there is a later VW ALH engine at idle TDi engine, the green trace is a needle lift sensor on injector #3 , used to determine injector pump timing relative to the crankshaft which the red trace
the pizeo input "Needle lift sensor " is as usable for rpm as the crankshaft sensor waveform
or
a sensor near the flywheel teeth
blue
another pressure differential sensor measuring pressure change in the crankcase , blowby from the piston rings , all are uniform , good
The Following User Says Thank You to mwebb For This Useful Post:
NachtRitter (05-16-2014)
Old 05-16-2014, 01:28 PM   #9 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Using rpm and tps for determining fuel used in real time
I used a korean polynom developed in 2011 for a 3.3 gasoline car, to develop a more general model to be used by dinosaur cars (like mine) which don't have all the sensors as to measure fuel injected.
Look the spreadsheet I am attaching and give your comment. My car has a VSS signal but don't have an injection fuel volume signal. I plan to make it of tps and rpm using this model. The model has to be callibrated to each particular car. For this you must produce several point (fuel used, rpm, tps) and try to make the model pass exactly through this points. For that, I provided two constants: one zero constant to lift or down the complete model, and one scale constant to lift or down the slope of the model. Plus, you have to record mean fuel consumption to compare to full tank consumption.
Of course this is a simplification, but such a model should be suitable for making relative comparisons, and acceptable for absolute figures.
OldBeaver
File Type: xls Consumo de combustible vs rpm y tps.xls (60.5 KB, 73 views)
Mercedes 300 D turbo 1993
Old 07-27-2014, 07:16 PM   #10 (permalink)
Two flow meters and a digital display
Fellows,
This guy in India sells a system consisting of two diesel fuel flow meters and a LCD digital display that calculates the difference of the two, for net fuel consumption (liters/hour).
The only thing missing is to take speed in km/hour and divide by consumption, and we will have fuel efficiency in km/liter (or miles per gallon).
The result may be shown in the same digital display.
Look here:
Fuel Consumption Meter - Diesel Generator Fuel Consumption Meter, Automobile Fuel Consumption Meter, Vehicle Fuel Consumption Meter and Fuel Consumption Calculator Manufacturer & Exporter from Mehsana, India
I have asked for a quote but no response so far.
Oldbeaver
