EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   how do you fill up (https://ecomodder.com/forum/showthread.php/how-do-you-fill-up-18516.html)
drv2die 08-15-2011 01:51 PM
how do you fill up
sitting here reading along happily and thought i havent seen a thread on how you fill your tank. do you pump it until it is in the filler neck stop at the click, round up . shake the nozzle for every last drop?
my car you are suppose to stop at the click if you fill it into the neck the extra will run down the canister vent and into the canister where it ruins it. so i stop at the click and then give a couple of shakes to make sure i got everything i paid for. is there a method that could lead me to easier calculations?
Angmaar 08-15-2011 02:05 PM
I pump it until it clicks then add another "click" of fuel.
gone-ot 08-15-2011 02:47 PM
http://ecomodder.com/forum/165549-post4.html
moorecomp 08-15-2011 03:34 PM
I use the second notch on the handle to keep the fuel flowing (not the fastest setting). I fill till it clicks off, let it settle a while, fill slow till it clicks again and then round to the nearest 10 cents.
CigaR007 08-15-2011 03:52 PM
I stop after the 1st click followed by a 90 degrees rotation of the nozzle to the left and right.
gone-ot 08-15-2011 04:04 PM
...a "twister" not a "shaker"?
UFO 08-15-2011 05:10 PM
My tank filler is vertical. I've removed the tank expansion vent (my tank is vented as its a diesel), so I fill the tank until the level is three inches from the top.
CigaR007 08-15-2011 06:17 PM
...in this case, yes..
Otherwise, no.. :D
gone-ot 08-15-2011 08:48 PM
...as James Bond would say: "...shaken, not stirred..!"
dcb 08-15-2011 09:57 PM
first click, usually same pump, handle vertical and fully inserted.
Frank Lee 08-15-2011 10:41 PM
That's only because you haven't looked for them.
pounsfos 08-15-2011 11:19 PM
I fill it till it clicks, then manually fill it till i can see the fuel, Their is a line in my tank and i go by that,
my car doesnt have none of that safety cr#p in it, just piping to the tank and thats it,
And thats how it should be
busypaws 08-16-2011 12:44 PM
On the nozzle I use the 2nd indent for medium speed filling, when I get close to full I go to the slow speed. After first click I manually squeeze handle slow speed untill second click. (Never tried the twisting instead of the shaking, I'll have to experiment). I miss the old pumps where you could turn the pump off (lever down) and then move the hose around with the handle squizzed to get all the fuel out of the hose.
Ford Man 08-16-2011 10:25 PM
I can still do that on most of the pumps in my area and get an extra half cup or so. I put every drop in that the tank will hold.
drv2die 08-17-2011 02:13 AM
i did do a search for (how to fill) came up many many pages went through them well 9 of them and didnt see what i was looking for.
i have on occassion pulled up with the filler door away from the pump and then ran the hose over the back of the car not touching it of course. but only if im in a hurry and there is a opening
euromodder 08-17-2011 05:17 AM
I shove the nozzle into the filler tube to the same depth, then stop at the first auto shut-off.
It seems to be pretty consistent.
What error there is, will even out anyway.
jamesqf 08-17-2011 12:29 PM
These days I don't. The El Cheapo stations I pass have the lowest price for cash, so I stick a $20 bill in the reader. That's something over half a tank, and generally lasts 3 weeks to a month. (Honda Insight, 70+ mpg :-))
But in the days when I did, I'd just stick the nozzle in on the lowest notch, leave it while I washed the windows, and let it click off.
Arragonis 08-19-2011 08:49 AM
I do this and always have. There are big signs at the stations here - fill up on both sides, and queues of morons who seemingly can't read but get very annoyed when I go straight to the empty pump.
There is a collar on the inside of the filler tube to George's tank which stops people putting in the larger Diesel pump end in, er, so to tap. I fill it until the fuel is at the bottom of this collar which is consistent and leaves a couple of inches for expansion.
Spills kill bikers, and all that.
Mustang Dave 08-19-2011 10:20 PM
That's my method, as well. At the same fuel station and the same pump, if possible. It's quite consistent.
Arragonis 08-20-2011 10:03 AM
Of course there is the "buy your petrol on a cool day because its more dense" debate ?
Varn 08-22-2011 02:19 PM
I purchase fuel at the same pump most every time. I fill it and let it click off 3 times. I don't see how you can look down the tube to see how much is in there.
drv2die 08-23-2011 03:25 AM
i have also heard about the filling when the temp is lower but im not sure if there is anything to it. would be interesting to find out.
vinny1989 08-23-2011 07:01 AM
Theres a joke in there somwhere :p
I try to fill up at the same pump every time. Its a pay@pump, so i dont have to take off helmet or anything (Im a Biker). Bike on side stand, fill until at bottom of tank filler neck pipe thing, then pump up to the nearest 10p/£1.. pretty consistent £13..
Oh, and im a shaker, gottta get every last drop.
Anyone else noticed that sometimes the fuel starts flowing a second before the number start counting?.. couple of ml free fuel?
