EcoModder.com
-   -   How to fix horrible mpg on 2009 nissan sentra? (https://ecomodder.com/forum/showthread.php/how-fix-horrible-mpg-2009-nissan-sentra-41487.html)
09Sentra 07-30-2024 08:48 PM
I get about 17 mpg in the city with my 09 sentra.
Its a 2.0 ,automatic.Any way to fix that?Thanks.
freebeard 07-30-2024 10:19 PM
ecomodder.com/wiki/Main_Page#Tips_and_Modifications
09Sentra 07-30-2024 11:08 PM
The problem i think is ,that according to the door label, this car weighs 3974 pounds-which is nuts.When i go to the epa site it says it should be around 24 city.
CigaR007 07-31-2024 10:51 AM
Is the general maintenance up to date ? 17mpg is really low for city driving. What is the average mpg on the highway ? Is it closer to the EPA numbers ?
Isaac Zachary 07-31-2024 08:23 PM
I get terrible fuel mileage in my Avalon hybrid in the city. It depends on a lot of factors, but mine are really short trips. The engine tries to warm up the cat by retarding the timing, which is terrible for fuel efficiency. One thing I want to do is get a better block heater. I'm not sure if that would help the OP, but a pre-warmed engine, which will warm the cat more quickly, will most likely help.
Ecky 07-31-2024 11:07 PM
This is probably the weight with maximum payload, not the weight as it sits.
Minimize sitting in traffic, idling. Minimize cold starts. Minimize use of brakes, and stop-and-go. Maximize moving along at a slow and steady speed.
09Sentra 08-02-2024 11:46 AM
Arent you supposed to get better mpg in the city with hybrids?I was gonna buy a prius.
Isaac Zachary 08-02-2024 04:29 PM
For the average driver on the average daily trip, yes. For me, no. Because:
  1. My city is about 5 miles wide, with zero points of interest, stores, schools, etc. outside of that 5 mile wide circle.
  2. It is cold here nearly year round, already dropping down into the 40's °F at night. Try starting up at -40 °F several nights/mornings in a row with a wimpy block heater that won't bring the engine up past 0 °F even when left on all night.
  3. My work is not just one place, but several small stops all over town, where the engine has a couple hours to cool back down each time, especially during the cold winters when I work nights.
Most people just get in, drive 7 or 8 miles to work, which in stop and go traffic means they're warmed up by the first mile or two, then the hybrid system can do its thing the next 6 miles. Then they get back into their car on a nice warm/hot afternoon after work, so it takes half a mile to warm up, then the hybrid system does its thing all the way back home.
Gasoline Fumes 08-02-2024 09:34 PM
How long are your drives? What's your tire pressure? Are your brakes dragging?
