How get a shorter belt........
How does one get a shorter belt? In this case a serpentine. The easiest way is to get a belt from a truck that doesn't have a/c. But if I wanted an even shorter belt I could measure it. But I can't imagine the local parts guy (even though I know him) would be completely happy with me if I said "I need a belt that is 42" long".
I probably could run nothing at all since the injection pump and the power steering/vacuum pump combo are gear driven. The power steering with the piggyback'd vacuum pump combo could probably be replaced with an electric vacuum pump and the power steering could theoretically be replaced with an electric pump but I need a real heavy duty unit. I need to try out different combos of a/c and alt. for mpg reasons and for a standing mile run later on this year. I'm already planning to ditch the fan and water pump with electric versions Any clever ideas on the belt situation? Cummins 5.9 12v diesel |
How I do it is.
Cut your existing belt, Hold your tensioner about where it need to be (or a little looser). Then keep cutting little bits off until you have the length you need, measure, purchase. Or you could just buy several and return the unused ones. |
You should go to your local industrial power transmission distributor (such as motion industries in the US, or Kinecor in Canada) with the specs of the belt you need. They'll find something that fits for sure.
Since your engine is most likely one in a "family" maybe a belt from another application of that engine will be suitable.
Marine engine , stationary generator , water pump or something like that. Pete. |
local parts guy sure does have belt catalogs by lenght, width etc.
