Old 12-31-2010, 03:41 AM   #1 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Glow plugs on a VW diesel
1) Go buy a 5/16ths or 8mm and a 12mm flex head gear wrench. Or use standard wrenches you cheap *******.
2) use the small wrench to remove the nuts from the strip on the glow plug power lead. When you get to the ones behind the injector pump the process goes as follows.
put wrench on nut and turn one flat, drop wrench, go to the store and get a small magnet on a stick, retrieve wrench. put wrench on nut turn one flat, drop wrench, use magnet to retrieve wrench, put wrench on nut turn one flat, drop wrench, use magnet to retrieve wrench...
or
use gear wrench and zip the little buggers off.
no a socket won't fit.
3) clean the brass strip and set it aside.
4) using the 12mm wrench remove glow plugs in a similar fashion to the nuts.
5) put new plugs in and torque to the books specific specifications, or till they are tight enough, what ever.
6) put brass strip back on and secure it.
7) try to start the car.
8) remove the nut from the left most (your right as you face the car) glow plug and put the lead from the relay back on.
Done.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-31-2010, 08:13 AM   #2 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
you forgot the swearing!
Other than than, an accurate representation
Old 12-31-2010, 10:04 AM   #3 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
Love it!!!!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 12-31-2010, 01:22 PM   #4 (permalink)
Smeghead
oh vea, but the svearing must be done in German other vise the kar kan't understand vou.
Old 02-24-2011, 10:59 PM   #5 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
When I replaced a glow plug or two on my old VWs, I pulled the conducting strap off and then used a box end wrench to bust them loose. Speaking of which, I still have several of those tools still...but no diesel VWs.
