how much do the stock 2001 Prius 14" wheels weigh?
they don't seem to have a "name", just a number 69453
2001-2003 Toyota Prius 14" 69453 - All Factory Wheels http://www.allfactorywheels.com/prod...88528_zoom.jpg I'm just curious as I picked up a set of VW "le casselettes" with some nearly new Blizzak WS50's for my 01 Prius they are FORGED, and I believe they weigh about 15.4lbs each Le_Castellet.jpg http://i201.photobucket.com/albums/a...s/HPIM4512.jpg |
Check out WheelWeights.net - Database of Wheel Weights ... that list MIGHT have some answers. Another way to do it is weight the wheel/tire combo and estimate the wheel weight by getting the tire weight at tirerack.com and subtracting it from your measured total weight ... not a precise measure but if it's all you have for data and you only need a rough number ...
Thanks, I've got a scale, but wanted the official weight your link shows a spreadsheet Toyota Prius 01-03 Cast 14x5.5 weight 13 lbs / KG 5.8967012 that seems very light |
