? How much EV1 DNA did GM put into the Volt?
Just wondering if GM put the lessons learned from building the EV1 into the Volt OR was all that valuable knowledge lost when GM crushed all the EV1s.
It was 20 years ago, a lot of the senior people probably are retired.
After we went to the Moon, NASA burnt the blueprints. GM may have done the same. |
Well, the little "Body by Fisher" logo is definitely gone!
I'd wager the honest answer is little to none. The Volt is based off of the Cruze platform, using completely different battery chemistry and hybrid technology.
markweatherill -- Of course we went to the Moon. You can point a laser at the reflector that was left there.
What I don't understand is why they run a chemical rocket program in parallel with the antigravity stuff. And there's an EV1 in America's Car Museum in Tacoma WA. Old Tele man -- :) |
Wasn't aware of the connection of Cruze to Cobalt. Yes, according to Wikipedia, one was Delta I and the other Delta II, but I am not aware of any connection between the two platforms, as the latter was developed by Opel, not GM. Furthermore, the engineering for the Cruze took place mostly at Daewoo/GMDAT, where it was designed as a replacement for the Lacetti (Suzuki Forenza to yon Americans) further distancing it from the US-only Cobalt. |
I saw an EV1 at Virginia Tech. The engineering students did not think much of it, called it junk. Maybe that's why they crushed them. I did not look at it closely or question the students about why they felt that way about the car.
regards mech |
Probably because it didn't go 400mph
Yes, the Cruze is basically a DAEWOO-redesign of their Lacetti...with GM trims. Remember, soon after the design process, DAEWOO Korea was FULLY bought by GM.
Lord knows why... it was always the worst of the Korean big three... :D
